I think a lot of folks would suggest the best upgrade would be the removal of any fake logos.
As for the pickups - I'd suggest looking at Iron Gear or Artec
Best to go for a full wiring kit (and more economical) - I usually use to All Parts or Six String Supplies
http://www.allparts.uk.com/collections/guitar-and-bass-electronics/wiring-kits-for-guitars-basses
http://www.sixstringsupplies.co.uk/wiring-kits
You need to work out if you need long/short shaft pots
Also, be careful with the toggle switch - either use a short frame version of the switchcraft toggle, or the long frame version with the deep threaded nut. Without the nut, its unlikely the thread will go through your Chibson's top. I found this out the hard way and had to get a deep threaded nut separately.
if you want proper high end sound pafs then Deacci LP-Zero set. Sure they are about £130 a pair uncovered with covered being a little more expensive. That's less than most big brands charge for factory wound paf's and you'll get seriously good sounding paf's that will rival the real thing and very best hand wounds.
