1 - a long block of wood with a couple of countersunk holes drilled in for the feet to sit in. This is the same width of the board.
2 - 4 rubber door stops drilled out and then glued over the original feet with a hot glue gun. This was a royal pain to do but worked.
I've subsequently discovered the Palmer Pedalbays which offer a great alternative to Pedaltrain.
