AB selector with built-in amp switching?
TrudeTrude Frets: 914
Let's say I have two guitars, which I need to switch between on the fly.  One is set up to use Ch1 of my amp, the other Ch2 (using a common input).  The amp has a standard 1/4" jack socket for channel switching.
Does anyone know of an AB pedal which can also switch the amp channels with a single button press?  I'm sure some of the fancy Gigrig units can do this, but I want something small and simple that just does this one job ideally.
If you're interested, guitar 1 is a Tele.  Guitar 2 is a squareneck dobro, which wants to use the acoustic channel of my Boss Katana.  I have the dobro on a keyboard stand, so I can go between it and the Tele in a single song.  I'd like to make the transition very slick and idiot-proof between the two.
Some of the gear, some idea
Trading feedback here
