I've owned a Klon - I get it
Or possibly even a G7 capo...
It's a chunk of money, but if it works that well it doesn't seem particularly unreasonable for someone who makes a lot of use of capos.
I didn't realise until I looked at their website in response to the OP that they brought out an updated version of their normal capo a couple of years ago. I'll wait until I lose or break my current ones though.
I had one of the updated Performance2 capos. Lovely capo.... much lighter and less obtrusive that the Performance 1. But had to send it back because it just didn't work well with the compound radii on my main acoustics. You had to squeeze it way too hard to get firm contact across all the strings, hence my keenness on this one.
Capo di tutti capi........
Too expensive
There's things I've had, there's things I wanna have"
By putting the capo too far from the fret by a specific distance, the strings go slightly sharp - but then by deliberately using the friction under the capo, which can be a problem when you bend strings because they can end up flat, he can pull them into tune.
https://elliottcapo.com/shop/item.aspx?itemid=26
Shubb also have one, which is $75
The Fine Tune is absolutely fantastic. Cost about £79 and it worth every penny. Ive been meaning to write a review for ever...
My trusty old Dunlop is failing (rubber lining coming loose). It's the only capo I've ever had, so not sure what I might be missing.
Would you buy the G7 again?
