Larrivee vs Martin
  • ToneControlToneControl Frets: 11791
    try it  away from the window - just in case that's a funny spot
    in a water-tight house, with the heating on when frosty outside, you should be getting RH below 35%
    So I'd wonder if you have a bit of damp getting in to the house
    you don't use calor gas heaters in the house?
  • LewyLewy Frets: 4127
    edited December 2016
    I wish....I've never had lower than around 55% RH in any conditions anywhere I've ever lived. Normally it's up above 60% if left unchecked.
    I must have a very humid lifestyle....
  • thomasross20thomasross20 Frets: 4423
    No calor gas heater.
    I just opened the window and it went from 70% to 64%. Edit - now it's at 60%. Wtf.
    I'll leave it a bit and place it at the other side of the room.
  • Is there a vent on the window?
  • Yeah but I keep it closed..
  • My thinking was the vent would let moisture in but maybe I'm trapping it instead.
    Maybe I'll buy a little one.
    Is there a decent dehumidifier you guys might recommend?
    you should never need a dehumidifier to look after your guitars in the UK, unless there is seriously something  unusual with the room (i.e. damp cellar,  leaky roof,  full of tropical fishtanks,  used as a kitchen, used to dry clothes)
    RH  in a UK house is typically  based on what it is outside, plus the effects of central heating (CH) and living (breathing, cooking,  washing, etc). In the UK, we almost always want to  increase indoor temp above outdoor temp,  or  throw open all the windows. Few use air con to chill the air.
    Roughly, raising  air temp by 20C doubles  the water it can hold, so if it's 50% RH outside,  at 5C, and you take that air and heat it to 25C, it will be 25% RH
    In real terms this means that in the  summer, with the windows open, RH will be similar to outside, usually 45-55%. It rarely goes past 60% in the UK. In Florida or Japan it is a different story
    In  the UK in the winter,  with the heating on, RH indoors is usually 32%-35%, rarely more than 30%
    On cold dry days, outdoors air is very cold and dry already, heat that air and  get it indoors, and  even with breathing and  cooking, UK indoors RH can be 27% or less on a snowy day. Offices  and hotels are very bad for this
    In the spring an autumn, indoors air is often 35% or 37% in houses I've lived in
    Air con dries the air in the reverse way: it  cools air, and the water falls out of it, then adds the air back to the room.
    Heavily airconditioned rooms can get too dry for guitars in the summer. More advanced air con adds moisture back into the air separately.
  • Good thread, it is making me think I should at least know what the humidity is in my house.
    Our double bass player has the opposite problem; his (circa 1860) bass dries out in winter so he has to put a wet rubber sausage thingy in his F hole(!). He likes to keep his house humid. I wouldn't lend him a paperback book. :)
  • BRISTOL86BRISTOL86 Frets: 1920
    My room is around 60-65 all winter. We do put damp clothes in there on occasion but even without it's rare for it to be below 55-60
    I think this is plenty of people's experience. I  can only think of a few days so far this winter that have been particularly cold and dry...mostly they've been kind of damp and really not that cold....the CH has only needed to go on for an hour or so a day max over a 8-12 week period after which it's not on for the rest of the year pretty much.
    Humidity in the house north of 55% the whole time. No way I'd be able to properly look after my good acoustics without a dehumidifier and very good cases, which the guitars live in when I'm not playing them. I use these to ensure the cases are providing suitable protection: http://www.planetwaves.com/pwhumiditrak.page?sid=8b8529dc-67ad-427b-b73d-6834da5391a1
  • davewwdaveww Frets: 165
    edited January 2017
    I got myself an HTC-1 and the humidity has stayed at around 40-45% throughout the couple of months I've had it.  Can't vouch for its accuracy but it seems accurate at recording the temperature.
  • Going to try and calibrate this thing this week and get another for reference. Willing to splash a couple hundred on a proper dehumidifier in order to protect the room and guitars.
    I have an older version of this one, which does a good job:
    http://www.appliancesdirect.co.uk/p/cd20le/electriq-cd20le-dehumidifier?refsource=Apadwords&gclid=CM-ExOHitNECFYwy0wodgj8Irg
  • How noisy is it (if noisy, do you turn it off at night?) and does it make a noticeable difference in energy bills?
    I'm getting a loan of one off a guy at work for a week so will see how it does. No point spending thousands on guitars and skimping on something like a dehumidifier!
  • Have you tried opening the window vent yet?
  • Yeah I did that. Didn't make any difference :(
    try testing some other rooms in the house, to see if that room is damper than the others
    if it is, I'd be looking for leaks first (pipes or rain getting in)
    I thought 40-60% was considered the happy zone? If it's 55ish year round then you should be ok without dehumidification shouldn't you?
    I use the cheapy room dehumidifiers that collect moisture and just move my acoustic into another room anytime there's washing drying in that room.
    In my experience the zone within which you are avoiding damage is broader than the zone where my guitars sound and play their best. I can hear/feel a difference between 45% and 55% and definitely 60% where unchecked humidity would gravitate for a lot of the year. So I keep the guitars as close to 45% as I can because that's how I like them, even if they wouldn't be at risk at higher humidity.
    My house isn't a leaking pile of damp either ... I just happen to gravitate towards putting on a jumper rather than running the CH all year.
