Matrix power amps, any experience?
professorbenprofessorben Frets: 5105
edited January 2017 in Amps
@digitalscream has raved about their speaker cabs, but anyone tried the power amps, specifically the GT800fx???
cheers.
  • BGGBGG Frets: 689
    Only ever hear great reports on them.
    #thebatesmotelband
  • monquixotemonquixote Frets: 17603
    Moved to the right section.
    My concern with Matrix is that everyone I talk to seems to say. "Matrix are great, they were brilliant about fixing mine when it broke".
  • Moved to the right section
    apologies, the £ sign was obscured by wine.
  • Moved to the right section.
    Hmmmm so reliability issues?
  • JetfireJetfire Frets: 1696
    Ive had one and it didnt play nicely in my set up. I had a TC electronics G major, Laney IRT studio and a GT800 (I think it was). Used to go into protect mode all the time. However, it was fine without the G major.  I gigged with it for a while but got shot of it as I just didnt get on with it sound wise. I couldnt say what it as precisely but it sounded a little .... fake?
  • drwiddlydrwiddly Frets: 913
    I have a GT1000FX that I got a few years ago. I've had no reliability issues at all. It's very powerful with loads of headroom but I still prefer a valve power amp with my Axe FX or Kemper. Good as the Matrix is, it doesn't have the punch or the bloom of a valve power section. Just my opinion though.
  • Si_Si_ Frets: 384
    +1
    No reliability problems with mine (I've had a few), but thought they were "too stale", which may sound strange given that's what people want. Opted for a 1u Valve Power amp instead (Marshall EL84 one).
  • sweepysweepy Frets: 4183
    I use a Marshall 20/20 with my Axe-Fx with a pair of Yamaha CBR12's, works perfectly and is certainly loud enough ;)
  • I have the 1u GT1000FX. The fan is fairly noisy for low level playing but that's about it. It doesn't have the same thump as a valve amp but with the low frequency resonance control on the Axe FX 2 dialled to your cab you can get close enough. When I had a HD500x I wasn't as happy with the low end (it just was in the wrong place for the cab and also less dynamic). I guess you need a preamp that can put out a decent low end to begin with as the Matrix isn't going to add anything not already there.
    It is good at sounding tight but warmer/looser sounds are better and more natural with a valve power amp.
  • So a Mesa preamp dialled for thrash levels of gain are gonna sound huge??
    I reckon the GT800fx might be the way to go, if I do jump on the Kemper/Helix/HeadRush wagon I'm sorted too.
  • What I really want is for them to bring the GM50 module back - basically half a GT800FX in a module you can install into your cab to make it a powered cab. For some reason, they only sold them in packs of 5 (which is rather expensive).
    <space for hire>
  • DopesickDopesick Frets: 1508
    edited January 2017
    I believe Scott Hull of Pig Destroyer/ANb/various others uses the GT1000FX. He uses the Amptweaker Tight Metal Pro as a preamp and his guitar tone is fucking monstrous. Not really any tube sag going on but high levels of beef.
    +1 on that! When I used one with my Axe Fx, I turned it up to about half with the AF output on about 10 o'clock. It sounded massive but far too loud for use with a loud band. Who knew?
    They do run hot though and the fan exhausts to the side (bit weird for a rack amp!) I ended up drilling a few holes in my rack case next to the vent to prevent overheating.
    I believe mine had the vents front and back.
    One of the best sounds I ever had was with my Eleven Rack and a Marshall 20/20. I just don't understand why they included the Deep switch, because everything sounds awesome with it on and shit with it off.
    <space for hire>
  • p90foolp90fool Frets: 31577
    I wish I'd known at the time their factory was fairly close to me, I'd have thrown it in their skip instead of my wheelie bin.
  • fretmeisterfretmeister Frets: 24264
    Can the Marshall 20/20 run in mono?
  • Si_Si_ Frets: 384
    No, Stereo only.
