Open G tuning makes Keith Richards licks a must
Yes the inlays on the front of the narrow necked beauty are laid out like a bluegrass instrument - 10th inlay instead of 9th
We had a special 5 string hardtail bridge made just for this guitar
Oil City pickups made us some special 5 polepiece pickups with coil taps to go between a tele sound to a more P90-ish sound. These will have custom cut flatwork inside an open fronted humbucker shell.
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
Specially made 5 string "big block" pickups by Oil City Pickups .
These have a tapped winding to allow you to switch from a Telecaster type voicing and a P90-ish voicing
Would it be possible to ask who made the custom bridge?
Wasn't cheap in the end but was a tidy way to do it
Lovely work again.
The workmanship, weights, playability and resonance of these things are superb and whilst I really like the Lions, those Lion Cubs are pretty special.
Great guy, great guitars and good company, too. Nice chatting and catching up, Jonathan and cheers for sorting out my pedalboard.
Rear view showing the all access neck joint and the start style contours on the rear
Electrics are a trio of Bare Knuckle Irish Tour pickups and an LR Baggs piezo equipped strap tremolo bridge
We used Luminlay side marker dots that glow for an hour from a 5minute UV charge
The lean back headstock with a volute and locking tuners
An Earvana Compensated Tuning nut helps with giving the guitar a greater degree of in tune-ness
The back was done in satin finish whilst the front was all glossy
Seymour Duncan Tripleshot mounting rings allowing each pickup to be set for series humbucker, parallel humbucker and each of the two single coils chosen on it's own.
Pickups shown here are a pair of Oil City Masterwound Tubesnake model which were designed to give a vintage PAF with an alnico 2 magnet. The tone benchmark players were Slash and Billy Gibbons ...hence the Tubesnake name.
Or just needed a new neck and that's what was available ?
Russ' strat neck had a hole drilled in the headstock too and this made it split when it was dropped on tour some time in the 1970s. They found him a neck to replace the broken one and it happened to be a tele one. There wasn't anything more cunning than that , although it may be that he liked the feel of the neck.
