I'm keeping them on and letting them wear in. I presume they will only get better...
They don't half complement a P as well. Phew. I've put some rounds on my '74 P now as well and the contrast is just incredible. Still got Chromes on the Stingray, but wondering whether I should try something different on this now as well.
I'm definitely liking the 64 with TI's and the 74 with Rounds. Trad vs Modern.
On the flatwound sets I've tried, there is a huge difference going across the fretboard, with the low strings being really warm and thumpy and the G being really zingy and metallic, almost like a roundwound.
There is a change in timbre across each string, but it is still balanced tho - the G isn't particularly zingy and does still have warmth.
TIs are a bit odd for flatwounds - with the tone all the way up they are quite a bit like old dull roundwounds - dial the tone down a quarter turn and they are more flatwound..
Stick them on. You can always put the status flatwounds back on, and come back to them or flog them on as a used set and get a chunk of your money back?
TI's are great, the zing and top end will wear off a little and they mellow nicely.
After years of using TI's I've moved onto Ernie Ball Cobalt Flats. Well worth a try if/when you fancy a change. They are great as a modern flatwound, but of course not as a traditional one.
The Chromes really suit my P basses - the TIs are great and I don't mind the tension and the sound, but there's just something about Chromes I keep going back to.
I seem to flip flop between them!
