Sterling Sub 5 Bass
RockerRocker Frets: 4947
Anyone know much about this bass, Sterling Music Man Sub 5. Thin finish, blue/green - hard to tell, fairly heavy, nice price. Looks good to me, what is the general feeling about this bass? Thanks.
Nil Satis Nisi Optimum
  • steamabacussteamabacus Frets: 1258
    A friend of mine picked up a Sterling Sub 4 string a while back. It's a very nice bass and now his number one instrument - and he has a few much more expensive basses (Fender Jazz, Rickenbacker and others).
    I've not played it but I have sat in a rehearsal room with him playing it and remarked on how even across the neck it sounded.
  • FunkfingersFunkfingers Frets: 14323
    Sterling By Musicman SUB Series instruments are Crafted In Indonesia at the Cort factory. The basic woodwork and fret finishing are of a high standard. In my opinion, the bridge, pickup(s) and control electronics are serviceable but would benefit from being upgraded as soon as funds allow.
    The wood used to make SUB bodies tends not to be very pretty. Hence, it is probably wise to avoid the translucent finishes. Black is especially handy for disguising any screw holes exposed if/when a better bridge is installed.
    The Sterling By Musicman RAY34 and RAY35 series of bass guitars is noticeably better in several departments but not necessarily by enough to justify spending double the money.
    An S-By-MM SUB 5 with a Bartolini, Duncan or EMG pickup and upgraded EQ would do the business.
    Be seeing you.
  • fretmeisterfretmeister Frets: 23955
    The Ray5 shape is quite heavy. Not much can be done about that. Might not suit your back problems.
    You might want to have a look at an Ibanez SR series. The SR505 is a great instrument. Nice and light, quite narrow string spacing though.
    Many 5 strings have 19mm string spacing at the bridge.
    I'm not sure about the "Sterling by EBMM" ones, but the US Musicman basses are all 17.5mm at the bridge.I assume the "Sterling by EBMM" will be the same.
    Ibanez SR series are 16.5mm at the bridge and the BTB series are 19.
    It goes a long way to comfort. 16.5mm is too tight for me for slap but ok for the rest.
    The Ibanez necks are quite thin compared to Musicman instruments too.
    On the four string models, the USA and S-By-MM 'Ray models both have 19.5mm saddle slot spacing. The S-By-MM bridge is a slightly more cheaply made replica of the short-form American design.
    The Cort-built S.U.B. series uses a generic P.O.S. stamped steel bridge with skinny saddles and small wood screws instead of the big lock down bolts.
    Be seeing you.
    We are talking about 5 string models only.
    Uh-oh. Patronising, "newbie-assumed-to-know-nothing" syndrome.
    I was merely drawing the parallel between the S-By-MM and USA designs. It is extremely likely that the five string bridge designs are equally similar.
    Likewise, the four and five string Cort-built S.U.B. series suffer under similarly generic P.O.S. stamped steel bridge designs.
    Be seeing you.
    Not in the slightest. Never done that, never will.
    Just don't want Rocker getting confused. At his location the chance to try before buying are minimal.
    Mea culpa. I've spent too long on a well-known Californian pickup users group forum. Some of the "lifers" could be condescending to new arrivals. (By the same token, some of the newcomers probably deserved the derision that they attracted.
    Be seeing you.
    No drama.
    I had a similar experience when I joined the EBMM forum.
    That being said I definitely deserved it. It was bad enough when I showed them a picture of my limited edition 5 string 'ray with Hipshot Ultralites on it...
    But when they saw the twin EMG humbuckers and the paisley scratchplate they went mental. :D
    Been there. Witnessed that. ;)
    If you really want to foment apoplexy, post photographs of modified Rickenbacker 4001 and/or 4003 basses.  ;)
    Be seeing you.
  • SnapSnap Frets: 6256
    I have a SR370 and its blooming lovely, Very well made, plays and sounds great. 4 string, but does indeed have a very narrow neck at the nut., which (IMO) bodes well for a 5 string variant. Tbh, I hardly every use the first fret, but that is because at moment I am busy immersing myself in all things fretless wankery at higher frets type stuff. ;)
    Was it the bloke in Saxon who always tried to write parts where he didn't have to use his left hand much - to leave more time for pointing!?
    Seems like a good idea to me!
    Meh. I get enough derision and stick on here as it is without going elsewhere.
    And I'm a newbie as well.
  • RockerRocker Frets: 4947
    edited May 2017
    @fretmeister said it perfectly "At his location the chance to try before buying are minimal"
    And accepting the wisdom of the forum members, my search is now focused on 4 string basses.  Priced in the €250 to €500 region.
    Following frets suggestion, I looked at :
     (on the Thomann site)
    Ibanez SR300EB-CA
    Ibanez SR370E-SPB
    Which led me to:
    Squier SQ Vintage Mod JB 77 3TS
    Squier Deluxe JB IV 35B
    Squier SQ Vintage Mod JAZZ 3CSB
    And I ended up at:
    Marcus Miller V7 Alder-4TS
    I did not get to the Fender page, there might be suitable models in the MIM ranges.
    So has anyone any knowledge or experience with any of the above.  Or indeed, suggestions of other basses to check out. The Marcus Miller range looks impressive, TBH I never heard of Marcus Miller before - a bass with his signature may not be the sound I am looking for.  And there again it just might.
    The music I play is mainly Country, Pop and singalong songs [at my friends house one evening every other week].  My bass is an Aria STB [active Jazz type] which works but I realize that the sound is very generic and lacking any real depth or quality.  Also I don't have much experience playing other basses.  When I bought my Markbass amp, the seller let me use his Fender Jazz to try out the amp.  The Fender felt amazing to play and the notes had depth and clarity that the Aria can only dream about.  The Fender had flatwound strings but it gave the sound that was in my head.  That Jazz sets the standard, it is a question of how close any of the above are to the Jazz.
    Totally confused TBH and fairly certain that the shops in Dublin have few, if any, of the above.  Hence my request for help and guidance.  Many many thanks guys.
    From your list @Rocker, I would say the Ibanez ones. Quality has always been really good from what I've seen and they generally play and sound really nice.
    Buy online and you can send it back if you don't like it..
    Ibanez Soundgear, Crafted In Indonesia. Squier VM and Deluxe series, Crafted In Indonesia. Lower end Schecter and LTD, you guessed it.
    The Squier Vintage Modified Jazz Bass is consistently good. The ones with Duncan Designed pickups sound more convincing than the current Fender Designed pickups. I would take one of these over a MIM Fender Standard series bass.
    Be seeing you.
    Sounds like a good salesman. He has planted the seed. Now that you have heard and felt what a serious professional bass guitar sounds like, it will be difficult to be satisfied with anything less.
    The Aria STB-JB is normally a passive J-style bass. What active EQ and/or pickups do you have in yours?
    Be seeing you.
    Rocker said:
    And I ended up at:
    I do have a vague memory of doing a setup on a MM Jazz Bass - though for the life of me I can't remember when or who's it was. I don't have any strong recollections other than I quite liked it - I'm a guitarist not a bass player though, so I'm pretty easy so long as it has a skinny Jazz neck. I certainly don't remember any problems with it. Were they made in Japan?
    The Fender Marcus Miller signature four string was MIJ. The five was USA. More recently, Miller has put his name to an affordable starter/intermediate level instrument. It is reputed to be good value for money but difficult to find in Europe.
    Be seeing you.
    The Basschat guys seem to have bought most of the EU supply of the Sire basses and are very impressed with them.
