There has been a lack of love for Ashdown expressed on this forum lately. I came across this 4*10 cab and wondered it it would sound similar to the speakers in my Minimark 802. I don't want a 'different' sound than that from the Minimark, I just need a louder sound!
http://www.adverts.ie/speakers/ashdown-engineering-bass-speaker-450-watt/7724697So has anyone here any experience of this cab and will it give me what I am looking for? Thanks.
Nil Satis Nisi Optimum
It also seems a bit overpriced, but I don't know what prices or secondhand availability are like where you are.
It will most likely be noticeably louder than the Minimark though - in very rough terms, all else being equal (although that is a big assumption), four tens should be about 6dB louder than two 8s, ie equivalent to using four times as much amp power.
that might be all you need to know.
But at least they came with wheels!
Wheels might solve the moving of the speaker issue if the sound is what I want.
Mainly because it weighs 215 lb!!!
* The signal path diagram in the owner's manual suggests that it is not possible to run an extension cab instead of the internal eights. It is compulsory to have both.
