I'd say so. Won't cost much to get fixed (or DIY if you fancy).
In fact, having an Ibanez neck crack fixed next week. And it's a gazillion times worse.
http://i372.photobucket.com/albums/oo168/gusman2x/RG550DY/A7ADA1D1-8710-42F5-97C1-40465B2C3879_zpsqhp8lvsl.jpg
edit. I'm not a luthier.
Go for it. If it's affecting play then you are probly gonna have to sink a bit more in to fix, but it would still be a reasonable bargain.
Strictly speaking the split is only in the head, not the neck. As IC says, tricky getting glue in there and in fact I would bet a professional repair would involve cutting slots along the splits and fitting slivers of a similar wood.
Dave.
If you want to play safe, buy my Warwick Streamer Pro Stage 1.
