Precision pickups
RockerRocker Frets: 4947
Is it normal for the split pickups on a P bass to be slanted - the pole under the E is much further from the E string than the A string is from its own pole. And the D and G strings are similar to but opposite the E and A strings. The E and G strings are further away from their poles than the A and D strings. If you get my drift...
Nil Satis Nisi Optimum
  • FunkfingersFunkfingers Frets: 14324
    Short answer - yes.
    Be seeing you.
    What model you looking at?
    edited July 2017
    Doesn't matter which model. The idea is to set the polepiece magnet pair heights to approximately the same radius as the bridge saddles. (This even applies to the late Fifties Fender pickup with the longer rod magnets sensing the A string.) The objective is to get equal signal strength for all four strings.
    Be seeing you.
  • guitarfishbayguitarfishbay Frets: 7953
    Basically this, but tune it by ear.  The thicker strings can end up needing to be proportionally further away.
    The split P pickup is an awesome design.  It has the nice attack of a single coil, with none of the hum, and you can set it up so the strings have pretty even volume.
    I know people like to praise the Telecaster for its functional design but to me the split pickup Precision bass got it even more right all those decades ago.
    edited July 2017
    I meant which bass was it, as I've recently seen one for sale with very slanty pickups!
    The word "slanted" is imprecise and misleading.
    Setting a split coils P style pickup at any angle other than perpendicular to the string path is possible but of little consequence so long as the string excursion remains within the magnetic field of the polepieces.
    In recent weeks, the OP has repeatedly posted about buying a bass guitar - probably of the Precision persuasion - but never reported back to confirm that a purchase had been made.
    Be seeing you.
  • ICBMICBM Frets: 71963
    The idea is simply to make all four strings sound the same volume through the amp, there is no exact 'right' adjustment. It's very normal to see them like this, or with the low E side even lower -
    http://fenderbassplayer.com/images/articles/FBP-PBass9.jpg
    This is because of the fingerboard radius, the increasing action height on the thicker strings, and the greater moving mass (and hence higher output) from the thicker strings, all added together.
  • RockerRocker Frets: 4947
    You are right my friend. I have decided to buy a Fender Precision, probably Mex made and likely in early August when we return from holidays. I have checked out a few recently and noticed yesterday that some of the Ps had extreme slope on the pickups. Almost as if the instrument had received a hefty blow from rough handling. So apologies for all the questions about Precisions. The shops here have lots of white, black and red models. I have guitars in those colours and quite fancy a sunburst. The sunburst in the shop is a USA built model and is close to €2K.....
    Are there no pre-owned Fender USA basses for sale in The Republic?
    Be seeing you.
    There are a few but the prices being asked is close to what a new bass would cost.
    All Ps are different when it comes to the 'slope' I find. Setup to taste. You can see some of the slope on my 64:
    But it it depends on the pickup itself, the strings used, and the tone you are after.
    Looks like my Squier Silver Series.  ;)
    Be seeing you.
    Probly doesn't sound that different either ;)
    My Fender AVRI '63 P left the factory with an erroneously fitted AVRI '58 pickup. (Raised A polepiece rod magnets.)
    Unable to tolerate the anachronism, I installed a pre-owned Duncan Antiquity in the AVRI '63. The Fender '58 style pickup went in my ex-HarrySeven Squier. This pickup and the USA tort 'guard are probably more valuable than the rest of the Squier put together. With D'Addario flats, the Squier makes a fine backup for the AVRI. Shame that it doesn't smell as good.
    Be seeing you.
    Lol - I do like a good smelling bass ;)
    Somebody should produce air freshener with the scent of new guitar/case.
    Be seeing you.
    Sounds like the sort of shit Marshall would sell ;)
