I currently have a short scale Ibanez bass with an active pickup. It is okay but I want a full scale bass and something that doesn't look as bad.
So I'm thinking a Precision Bass. I've played Jazz bases quite a bit, they always seem big and round sounding. The impression I get is Precisions are a bit more focused and a bit harder sounding, probably less Jazz/soul and more suitable for funk?
Anyway, assuming this is broadly correct, what would be good to look at on a budget. Squire affinity series, or perhaps a classic vibe? Budget around £250, either new or 2nd hand.
Also, pickups, are the squire pickups reasonable? I only really know about guitar pickups, for example, the classic vibe ones are pretty good, but some of the Mexican ceramics are not great.
Another option is starting a partscaster build and buying the bits as I can afford them.
Funk is about syncopated timing NOT the instrument tones. e.g. James Jamerson on countless Tamla Motown hit recordings. Grooving all day but using the cruddiest, old flatwound strings ... in the world.
The 4001 in that video sounded off - as if it had a wiring issue.
Maybe, I am just looking for excuses to possess more than one type of bass guitar?
The Rick sounded as if it was clipping the recording equipment on the pick parts. If anything the one that sounded most wrong to me was the Jazz, they shouldn't be that thin normally. I didn't like the Warwick at all, which is also unsurprising.
Agree about the Warwick - horrid buzzy mess. I thought the P had the best individual note definition - especially later on, tho the Ric tone was very good.
The T bird was cracking for low down growl, but it just shows that it's not an all rounder.
I ignored the slap section. Ughhh. Slap = wrong on any bass.
The Jazz sounded quite horrific tho. Intonation was off, low mids were totally lacking and it was the most mushy. Poor choice of Jazz I'd say.
I use green Tortex picks with my Precision, and it's strung with flats. An unmistakable classic sound that leaves space for other guitars.
PS you can blame Kim Deal for the green picks
I've had my brother in laws early 90's stingray on loan for quite a while now and it's an absolutely stunning bass. But I recently bought a p bass from a forum member and the stingray hasn't really seen the light of day since. P basses do everything..........Well!
The Jazz and the Warwick sounded best on the slappy (yuk) stuff, but the P and the T-Bird definitely won in the more traditional stuff. The Rick just sounded terrible in all styles IMHO.
Surprised by the Stingray. I expected it to perform a bit better.
That's a 70s Jazz with the bridge pickup closer to the bridge. The typical spacing on most Jazz basses you'll find in shops (e.g. Mex and US standards) is 60's spacing, which has the bridge pickup moved further towards the neck. This will give a different scoop and a bit of a thicker sound than the 70s.
It's pretty hard to go wrong with a P bass, they'll work in pretty much any genre and sound great distorted too.
Personally I love Jazz basses for heavier more guitar forward genres. The natural scoop of a two pickup bass tends to leave a bit more room for a heavy guitar tone, when the guitar is supposed to be the driving force. In this scenario the bass provides the deep low end, and cuts through with some high end zing, but the rest is more left to the guitar. P's work great when the bass is supposed to be the driving force and the guitars less big. Gross generalisations of course! But that's how I'd approach them.
Listening from that perspective (and guessing what I'd probably do with the sounds) I preferred the base tonality of the Jazz and Warwick, but still liked most of the rest with my third favourite being the Precision - though as an isolated tone the P is probably nicest. I didn't like the Rick at all to be honest, I couldn't imagine using that sound at all, but I've never played one to know if it is capable of more sounds or sounds I would like.
It'd be a more useful test if there were more instruments involved, that way how it sits would have more context.
I recently sold mine - great bass, fab to play, beautifully built, but once I'd started playing P's I just preferred the tone from them, so the Stingray didn't get played as much (or at all!)
I think you either love the tone, or you think it's a bit meh compared to some others available..
In the video above, just thought the tone was meh..
For a while, I used to adjust the 3-band EQ on the fretted 'Ray to make it sound more like a P Bass. Strangely, I never found it necessary to do this with the 2-band EQ on my fretless. I have since concluded that this has more to do with the EQ circuitry than the mechanical aspects of these instruments.
P versus J? The midrange is in a different place and the split pickup gives more output, sending amplifiers into overdrive sooner.
The high pass filter in the 3EQ means you can get tighter rock sounds especially with lower tunings. You can change the EQ out to the John East one anyway if you want something closer to the 2 band.
Since I tune to a low B I do actually use a HPF pedal with my passive Jazz, the sub can get pretty big without it. I use the microthumpinator.
The placement on a P voices the low end higher up than the J, there's a bit less deep sub and generally more punch and usable thickness. That's kind of why they're hard to make sound bad, they just sit in an area that'll pretty much always work for a bass guitar. If you want to make the room shake a Jazz and a preamp with a 40hz bass knob like a Tonehammer works great though.
I think one of the main reasons people dislike the 3EQ is how high the treble is voiced, and that they add some from the 'flat' position and it gets a bit much very quickly. Most people I've met go for adding rather than taking away first, for whatever reason.
The low end difference is a lot to do with the 3EQ having a high pass filter which the 2EQ doesn't have. So if you want maximum rumble the 2EQ will do it best. The treble on the 2EQ is voiced lower too IIRC.
This product in theory makes it easy to get a 2EQ sound on a bass routed for the 3EQ, assuming you want to continue using the original jack position.
http://www.east-uk.com/index.php/bass/mmsr-4-knob-3-band.html
http://i.imgur.com/2rx4N7J.jpg?1
The really good thing on the 2-band is that the controls are useful through their full ranges - you can turn all the knobs up full and it still sounds great. In fact I think a lot of people do use them like that.
For whatever reason trying to introduce a scooped midrange doesn't work as well as attenuating highs, possibly because the character of the scoop from the Jazz/Warwick must be strongly linked to the phase relationships and positions of the coils (which you couldn't easily simulate with EQ).
Which is why I'd rather start with the Jazz, or the Warwick, than the Rickenbacker. Precisions seem to work well regardless, even if you distort them. Even though my favourite is a Jazz I do think (split pickup) Precisions are probably the best overall design Leo Fender came up with and generally the safest bet for a first bass IMO.
