Rift Tweed Vee (formally 'V-Front Super 5B4 Build')
RiftAmpsRiftAmps Frets: 3113
edited May 2018 in Made in the UK tFB Trader
As most of you know, I'm a bit of an enthusiast when it comes to vintage amplifiers. Anything pre-1980 really gets me going, and the older the better. I also do a lot of valve radio restoration and repair, some of the stuff I've worked on goes back to the 1920's. I stay away from TV sets though...flyback voltage can bugger off!
Anyway, Fender Tweed amplifiers have long been an obsession of mine and like most amp builders these days I offer a range of the most popular narrow panel designs - Champ, Deluxe, Pro, Super, Bandmaster, and Bassman. They're all fairly easy to do, parts are readily available, sound fantastic, and there are many good resources online if you need them. Want a high-powered Tweed Twin? Sure, let's do it. Need a Bassman in head format with a 2x12" cab? Go on then.
I also offer some of the older circuits, such as wide-panel and TV front models. These have proven to be very popular and I sell bucket loads of them. There clearly is a demand for these old designs and I'm not sure why no-one else offers them.
One of the amplifiers that I've always wanted to have a go at is the late 40s V-Front Super (pic below). It certainly has a unique look and sound, but information is scarce and finding one to play is even harder. Last weekend I realised that I actually had a few of the jigsaw pieces ready to go, and just had to find a way to get the rest.
So, this thread is going to document every stage of the research, build, testing, and completion of the V-Front Super, along with my ramblings and thoughts as we go along. I'm going to go full nerd on this, so brace yourself for lots of sums, measurements, and tedious back and forth. I'll include lots and lots of hi-res photos for those that just want to see the process.
I've also been following @WezV 's LP Prototype build on here, and as this would be an era-appropriate amplifier for a '51 Les Paul, it would be great to hear them together.
Rift Amplification
Handwired Guitar Amplifiers
Brackley, Northamptonshire
www.riftamps.co.uk
«13
  • WezVWezV Frets: 16546
    I am looking forward to it :)
  • Jimbro66Jimbro66 Frets: 2418
    I've booked a front row seat and a mega-tub of popcorn. Eagerly awaiting this thread :)
  • RiftAmpsRiftAmps Frets: 3113
    edited May 2018 tFB Trader
    So a bit of history to start with...
    The V-Front Super (named because of the cabinet design) was actually the second iteration in this line. It started in 1947 with the Dual Professional - a 20w-ish 2x10" Tweed amplifier, with both instrument and microphone channels. It sat alongside the Professional model (a 1x15" combo) but this one had two speakers, hence Dual!.
    Each channel had its own 6SJ7 pentode preamp valve, before being mixed and fed into a 6N7 paraphase phase invertor, and then into a pair of 6L6G power valves. Each speaker had its own output transformer, mounted directly on the speaker frame.
    The Dual Professional name was shortlived, however, and Fender quickly changed it to Super. They used the circuit designation 5A4.
    Rift Amplification
    www.riftamps.co.uk
    In early 1949, the circuit was revised to the 5B4 designation, and featured some big changes.
    Firstly, 6SJ7 pentodes were replaced by 6SC7 dual-triodes, again one for each channel but each half used for each input. The phase invertor was also changed to a 6SC7, but remained in paraphase configuration.
    Secondly, the dual output transformers were replaced with a single, larger unit - model #1848. This was a 6k6 25w unit with a single 4ohm secondary. The 1x15" Pro used #1846, which had an 8ohm secondary tap instead.
    Thirdly, the control layout was changed slightly.
    It is this version, the 5B4, that I'm wanting to recreate.
    Rift Amplification
    www.riftamps.co.uk
    Where to start then?
    With any amplifier build, one of the main considerations is the chassis and with Tweed amplifiers it's quite difficult because no faceplates are used. The chassis are manufactured from 0.06" thick cold-rolled steel, chrome plated and then silkscreened. For the most popular circuits, chassis are readilly available but for something like this there's nothing out there. If you want something, you have to get it manufactured yourself.
    This is what I did for the Tweed 30TV (5A5 Pro), I had a run of 26 units manufactured at an eye-watering cost, but it was the only way to get them looking right, and built to the specs that I needed.
    Fortunately, the 5B4 Super uses the same chassis as the Pro, so I can use those! There is one slight snag, I had the chassis manufactured 1" longer than originals. Looking at the dimensions of the V-Front cab it shouldn't be an issue, but it might be a squeeze.
    The eagle-eyed viewer will notice a few differences, mainly the inputs aranged in a square rather than a line. I chose to omit the ground switch from the chassis as it's not needed in 2017.
    Rift Amplification
    www.riftamps.co.uk
  • paulnb57paulnb57 Frets: 3044
    edited August 2017
    I can't pretend to understand the techy, nerdy bits, but I love this sort of thing, thanks for sharing, I shall follow with interest...I hate modern digital modelling stuff, what you are doing is real, proper, traditional, retro, right up my alley!
  • john_rjohn_r Frets: 123
    Will be following this one closely!
  • Winny_PoohWinny_Pooh Frets: 7732
    I'm curious as to what speakers are going in
    We shall get to that later :)
    Rift Amplification
    www.riftamps.co.uk
    Next stop: Cabinet.
    I've learnt a great many things about the cabinet over the last week, some of which are very interesting indeed.
    As far as I understand it, the cabinet designed changed quite a few times over the 6 year run of the Dual Professional/Super, but it can be boiled down into two main eras:
    • Dual Professional, 5A4, 5B4 - Type 1
    • 5C4 - Type 2
    The Type 1 cabinet wasn't manufactured by Fender, but was outsourced to a local cabinet maker. It was 22.5" wide by 19.5" tall, and featured a sloped front - bottom depth (at the Vee) was 9.75", and the top was 8.5" - giving a 1.25" taper. The sides were 1" less than the vee depth - 8.75" and 7.5" respectively. This meant that not only were the sides tapered, but the Vee was too.
    The Type 2 cabinet was manufacturered in house by Fender, and unlike the Type 1, it had no taper at all. Both the sides and Vee were straight (much like the Watkins Dominator). It was 1" shorter but also 1" wider 23.5" x 18.5". The depth was 8.25" at the sides and 9.5"at the Vee. On this cabinet, the Vee is 0.25" prouder than Type 1.
    Type 1
    and Type 2
    For this build, I'll be going with the Type 1 cabinet.
    Rift Amplification
    www.riftamps.co.uk
    The speaker baffles on this cabinet are interesting, as they are mounted to the cabinet using metal brackets on the outer side, and directly to the metal strip in the centre
    I'm particularly keen to avoid cabinet buzz and rattle, so we'll be using cleats to mount the baffles to the cabinet instead. This is still an era-appropriate method but will provide a much more stable platform. The metal strip on the front will no longer have a structural purpose, so it'll be made from polished aluminium and attached to the front with countersunk stainless steel screws.
    Rift Amplification
    www.riftamps.co.uk
    So, whilst I'm waiting for the cabinet to be made, we can start to have a look at the circuit.
    The picture above shows the layout for the 5B4 Super, but there is no schematic available that I can find. We can however, look to the 5B5 Pro for inspiration as we know the circuits are almost identical. There is a schematic for that amp.
    The most obvious difference is the output transformer and speaker config, but the sharp-eyed viewer will notice that the Pro amp has four 20uf 450v power supply electrolytic caps, whereas the Super has only 3. On the Pro, the reservoir cap is 2x20uf in parallel, giving a toal of 40uf. On the Super, it's just a single 20uf. This will give a slightly higehr and cleaner B+ voltage on the Pro, but not by much. In my build, I'm going to stick with the Super's config, and can always up the filter stage to 33uf or 47uf if I feel it needs it.
    Apart from that, I can't spot any other differences.
    Rift Amplification
    www.riftamps.co.uk
    Power Transformer
    The PT is listed as #6516, and the layout details that it has a HV 700v CT secondary (350v-0-350v), capable of supplying 140mA of current.
    Having experienced problems with Fender schematics/layouts before, I think it would be wise to workout exactly what we need and then comparing it.
    So, how much B+ do we actually need?
    Starting with the 6L6G power valves, the layout show a combined cathode voltage (Vk) of 24v, and a shared cathode resistor of 250ohms.
    Ohms law states that current (I) is voltage / resistance.
    So 24v / 250ohms = 96mA for both valves.
    Note - this is the Cathode Current (Ik) which is the sum of both the Anode Current (Ia) and Screen Current (Ig2) flowing through both valves.
    The 3 x 6SC7 preamp valves will typically draw between 1-3mA per triode, of which there are 6 in total. So worst case is 6 triodes x 3mA = 18mA.
    96mA + 18mA = 114mA - Somewhere short of the stated 140mA. Infact the PT is rated for 23% more B+ current. Amazingly, this is not as uncommon as you might think.
    What about heater current?
    Easy, we need two separate heater windings, one for the rectifier valve, and the other for the rest.
    The rectifier valve (5U4) needs 3A at 5V
    The rest are all 6.3v, rated as follows:
    2 x 6L6 at 0.9A each (1.8A)
    3 x 6SC7 at 0.3A each (0.9A)
    So we need a 6.3v winding capable of delivery 2.7A.
    Rift Amplification
    www.riftamps.co.uk
    Progress on the cabinet...
    Rift Amplification
    www.riftamps.co.uk
    Man Date.
    Nice bit o cabinatery
    You need to add this cab choice to the line up for a few more models.  How long is it going to be until someone asks for a WEM dominator style
    I plan to offer the V-Front cab with any of my Tweed circuits...eventually. This first cabinet is somewhat of a prototype to see how things go as it's built to vintage spec, I might have to tweak the dimensions to
    accomodate different sized transformers etc. Once we've got the design where it needs to be we can then offer it in numerous Tolex/Grille options.
    Rift Amplification
    www.riftamps.co.uk
  • DanielsguitarsDanielsguitars Frets: 3261
    Lovely work, are there any sound clips on you tube of these amps, I'd be interested in how they sound compared to the normal fender stuff
    www.danielsguitars.co.uk
    (formerly customkits)
    The best one I've found is this
    Also, I think that all of ZZ Top's "Antenna' album was recording using V-Front Supers and Tele/Esquires.
    Rift Amplification
    www.riftamps.co.uk
