Hi.
My name is TTony, and I played bass yesterday.
And I quite enjoyed it.
There, got that bit out of the way.
In the lead up to the forum jam session yesterday, I volunteered to cover bass on a couple of the songs just so that we had all the parts covered. I "learned" the bass part on the bottom 4 strings of a guitar, and transitioning to an actual bass (thanks
@bridgehouse!) didn't seem too hard.
I did briefly consider buying something pre-jam, but decided that was probably a little OTT just to be able to practice for a couple of songs for the one day. But, bass playing was fun. Plus I do keep promising myself that (when I get time) I'll do some proper recording with guitar (tick), keys (tick), drum machine (tick) and bass (no tick yet). Plus if I had one I could do some more playing at the next forum jam session.
So ... If I were now to go and buy an actual bass, where would I start?
I saw the PRS SE bass that
@Jonathanthomas83 acquired a few weeks ago, and I'm guessing that one of those would be a safe place to start, but I'd prefer to wait until they became a little more available s/h rather than paying the full £600ish new price.
I like the idea of a 5-string, but that might just be my sub-conscious justifying that if it's only got one less string than a proper guitar, that it couldn't be too bad.
I like the more adventurous designs (eg the stuff that @Andyjr1515 designs and builds normally grabs my attention!) too.
Thoughts and opinions on brands / models / things to consider to inform my choice / etc ... ???
Jazz's are similar, and both would be a 'safe' bet.
@Sporky was always going to say Stingray and they are great basses - they do most things well - you wouldn't be disappointed.
@ICBM will of course say a Ric, but they can be pricey...
Knowing you, and your penchant for a bit of workshop time.. I'd say get a @GSPBASSES body and neck and kit it out yourself - we could 'help' you to get the right pickup combo
I'd stick to 34" (full) scale if I were you, and I'd probably stick to a relatively well heeled pickup combo.
A Squier or a Mexican Fender and a small practice amp.
As I'm sure you know, You are the fundamental instrument in pretty much all music, so a different approach is needed, it's less about being the centre of attention and flamboyance of the guitar and more about groove and locking in with the drums, a good bassist will bring all the other instruments together and solidify the music.
Some like playing with a pick but for me fingers and thumb give you a bigger tonal pallet and flexibility.
Here's my one and only bass, it's used for stage and recording...
https://imgur.com/gallery/xVloa
A good sounding passive bass will sound great, and you can always add a preamp pedal later for more control as necessary.
I'd probably suggest starting with a 4 string bass. 5 string necks are wider and it's quite a big jump from guitar. Most guitarists can play most 4 string bass necks without too much hassle.
Watching YT comparisons now ...
I still need to sort out out a new bass for my son, when we tried a bunch the MIM precision came out tops, even compared to some more expensive basses.
He's got a Fender Rumble 40 combo which is incredibly light ( lighter than my tiny Fender Mustang II) and cost £100 used but sounds good and on an emergency was used in my band. Really clear in the mix, I'd assumed it was also going through the PA but it wasn't. Some amazing bass stuff out there.
Even I don't think you need a Rick as your first bass.
You can just upgrade to one when you get serious about it
It's actually harder - the neck feels much wider and more of a handful, and the tuning is more confusing because the lowest string is no longer an E, and the interval between all the strings is a 4th rather than one being a major 3rd, which is difficult for simpletons like me…
"And the Lord spake, saying, "Four shalt be the number of the bass, and the number of the bass shall be four. Five shalt thou not count, nor either count thou two, or three, excepting that thou then proceed to four. Six is right out! Four strings, four beats, four notes, the righteous bassist shalt live by this rule."
Yeah if he can play your Precision he'll be able to play any 4 string he fancies for sure
This one is pretty good for fingerstyle
Just the mutt's nuts for the money.
http://assets.fender.com/frl/1a6d8d0814a7394a1cc7b8dd58874ff2/generated/f9f9cc2d017d52e9db3f650dec1d0a50.png
I wasn't too keen on the Stingray at first @Sporky - it looked a bit "odd" to my eye, and the price tag looked too expensive - but watching the vid, I liked the sound.
Which leaves me with Jazz > Precision I think, just for the extra tonal options. I think.
Having done a quick trawl through the first few pages of ads, I didn't see anything that look bargaintastic in my price range. Will scan the local gumtree too, just in case ...
I'd prefer to spend <£500 on the guitar, which would probably just about allow a self-build if @GSPBasses had anything hidden under a pile of cobwebs in a dusty corner ...
