Thinking about bassing - comments/advice/etc invited.
  • I'd prefer to spend <£500 on the guitar, which would probably just about allow a self-build if @GSPBasses had anything hidden under a pile of cobwebs in a dusty corner ...
    My 52P GSPBASSES green machine came in at under 500 notes all up fighting weight.
    Knowing your current stable it might be the best bet for you ;)
  • TTonyTTony Frets: 27344
    equalsql said:
    Hmmmm, there's a J version - a *5* string J version just up the road ... collection only too.
    edited September 2017
    ESP Ltd for £120 ??
  • TTony said:
    ESP Ltd for £120 ??
    Personally, I wouldn't - but you can't argue with the price!
  • SporkySporky Frets: 27580
    The J is prettier than the P, but the Stingray is the best bass
    Prettier? With all that offset nonsense going on? After Leo had already perfected the design?
    PFFT.
  • JezWyndJezWynd Frets: 6021
    You appear set on 5 string. If you're just starting out I'd go with 4 (and stay there). Does it have to be long scale? I use a Gibson SG bass and I'm very happy with it; coming from guitar it might be a good halfway house.
  • octatonicoctatonic Frets: 33725
    TTony said:
    ESP Ltd for £120 ??
    Nope.
  • GSPBASSESGSPBASSES Frets: 2335
    edited September 2017 tFB Trader
    @TTony I do indeed have lots of bass bodies and necks gathering dust. I have some part built P bass bodies that could easily have the J pickup routed, a couple necks to go with them part build. I have several Jazz bass bodies, I think there is only one neck, that is a B grade nothing wrong with it apart from the binding has got some funny marks on the top of it. I also have Ricky part built. If you remember the pink one I made about four months ago this is its twin except the pickups are not routed yet still work to do to the neck, which has an ebony fingerboard. I also have a four string Stingray, the neck is not finished yet . If I remember correctly it's Maple / Maple. I also think I have two five String stingray  bodies nearly finished. I think one neck is finished and ones part finished these are also both Maple / Maple. Not sure if I've got any Warwick bodies and necks left in the workshop. its a while since I've made any of them. I also have a small boded Jazz bass with a 24 fret neck that only half built. They might even be Flying V Bass somewhere in the workshop half built.
    I may well be able to supply a fair bit of hardware to go with the bodies and necks. I certainly have a large range of four and five string bridges in stock. And if you're interested in a five string bass I have a complete set of active Seymour Duncan Jazz bass pickups with the active circuit to go with them. I also have lots of EMG active circuits in stock, which will be heavily discounted as will all the above necks and bodies.
    PM'd you ;)
    TTony said:
    ESP Ltd for £120 ??
    octatonic said:
    TTony said:
    ESP Ltd for £120 ??
    Nope.
    Messages received and understood - thanks.
  • Carl Thompson six string fretless "Rainbow" bass - as used by Les Claypool. ;)
    Be seeing you.
  • I think I smell a @GSPBASSES build thread coming soon..
    Well, I did finish my last contract on Thursday ...
    But I've got a long backlog of house jobs, and a bit of gardening to do (as in a full time job for the next 3 months)  and a cabinet making course to finish, and I told GSP that there was "no great rush", so breaths shouldn't be held just yet ....
  • Winny_PoohWinny_Pooh Frets: 7732
    Any reason you want to start with a 5?
    95% of music out there is comfortably played on a 4 string. 5s are also heavier.
    Nothing wrong with a budget P bass until you decide to upgrade. J's have smaller necks but sound a bit cleaner and nasal (on the bridge) than Ps, they work for funk and driven indie tones but a P has a better basic tone for typical rock music.
    Then again if you listen to some Sade and your mind is blown by Paul Denman (1993 concert dvd recommended) get a Sterling Ray 34 or a US Sub.
    Reason for a 5?
    Nothng other than I thought it might be 25% more useful than a 4-string ;).  Slightly more seriously, I thought the extra low end would make it bassier and give me more to learn.
    Im currently leaning toward a P that I could easily "amend" with an extra p'up.
    Or perhaps a 5er.
    TTony said:
    TTony said:
    ESP Ltd for £120 ??
    octatonic said:
    TTony said:
    ESP Ltd for £120 ??
    Nope.
    I was trying to be subtle...
  • octatonic said:
    TTony said:
    TTony said:
    ESP Ltd for £120 ??
    octatonic said:
    TTony said:
    ESP Ltd for £120 ??
    Nope.
    In that case I was positively cryptic...
  • TTony said:
    Reason for a 5?
    Or perhaps a 5er.
    5s are more about playing across the board rather than along the length - and less about extra low end.
    Go for a 4 - you really won't be missing out on very much at all
  • TTony said:
    Reason for a 5?
    Or perhaps a 5er.
    I got a 5 string for the extra low notes but in fact I very rarely use them. I also find that making sure that all the unplayed strings are muted when playing fingerstyle is a lot more tricky on a 5 string.
    It's not a competition.
