The spd etc would be better used by converting your ezdrummer samples to wav and importing them to the spd.
Typically, the Roland/General MIDI Map places the Bass Drum on note 35 and 36. Snare on 38 and 40. If EZ Drummer offers this option, try it.
In the longer term, it would probably be easier to leave the EZ Drummer software MIDI Note assignments standard and edit the SPD-X to comply rather than the other way about.
The older cheaper SPD will do the job just as well
