Friedman BE-OD
I don't really play heavy music but I've given it a go for this demo!
I'm not sure I'm going to be able to find a use for this pedal, even though admittedly it does sound great for certain things. There's so much gain it's ridiculous, there's even an internal pot that ads more! Anyone else got one?
  • CarpeDiemCarpeDiem Frets: 291
    Thanks for persevering and playing some heavy music for the demo - Wis awarded. I've got a BE-OD, which I use into a clean amp. I've turned the internal trim pot down to about 8 o'clock (almost minimum setting), and I can get classic rock levels of gain through to modern high gain. I find the sound doesn't get muddy, with the notes projecting through. As with most kit, it's worth spending some time adjusting the parameters to get the sound you like.
