This is why I bought a monitor wedge to use with my Helix.
R.
Eqd Speaker Cranker clone
It won't. That should work perfectly without the need for a dedicated speaker-emulator box.
You'll still need the (now silent) 4x12" on stage under the head or you'll look silly and Not Like A Rock Star though.
Question: does the line out come out between the preamp and the power amp, much like the loop, so I use a standard guitar cable? Except that it's "cabinet voiced" so probably eq'd?
It's not at speaker-driving current is it?
Mine either sounds revolting because it just does without the gorgeous Carvin Legacy power stage, or because my mixer / powered PA combo isn't set up for sounding like a guitar amp (or both)
@icbm or anyone else!
Get none of that with Peavey box, after my last gig on 20th, will send it to you to try one out if you like, not selling it but you can try it on a few gigs.
Are you SURE it's past the power stage? Surely then you'd need speaker cable into the box, not just a guitar lead, and something more substantial than mic cable after it? And you'd have to use a passive PA, wouldn't you?
Once into the DI box, this low-current 'tap' is converted to a balanced line-level signal that can be fed into a mixer.
Some of these boxes are passive - i.e. don't need any power supply - and others run off a battery or use phantom power from the mixer.
Offer stands anyway. If you look at my band YT vids over last 5 years it's all that DI box.
For what it's worth I think the Peavey EDI is transformer-based - I think it must be if it's passive - and I've always found these sound better for electric guitar however you're doing it, than the supposedly 'better' active type. (The Red Box is active, but to be honest I only really got it because it will accept a pedal-level signal as well, which I don't think the EDI will.)
