Acus One acoustic amp
ICBMICBM Frets: 71961
Anyone got one of these?
I've never come across them before but one came into the shop as a potential sale yesterday and I had a brief listen to it. My first impression was that it was quite AER-like, but actually sounded better. It looks solidly-made, but I haven't opened it up yet.
Made in Italy so my initial thought was that they were related to MarkBass in some way...
  • mgawmgaw Frets: 5239
    are these in some way related to SR Technologies?  think there was some kind of takeover?
  • ICBMICBM Frets: 71961
    Yes, from a bit of searching they're an offshoot of the same family business, or something like that. The amps do look quite similar.
  • camfcamf Frets: 1190
    I've had one for the last year. Great for acoustic rehearsals at home.
    The third channel makes a difference.
    This one is an older model 6, so only two channels - that would probably be a limitation for me too.
    Ah. Well it will be good to hear what you think of the build quality once you've had a look.
  • Chris_JChris_J Frets: 139
    I have a Acus One 6t and it's a fantastic amp, as you say very aer like but I find it slightly warmer and less clinical.
    I believe it's designed by the same tech as the Schertler series of acoustic amps.
    They seem to share a similar design though I've not tried one of them to compare.
    That's exactly what I thought from a brief test in the shop… although I'd maybe say a bit more than slightly.
  • I've got one. Bought after trying it against AER, Fishman and Tanglewood alternatives - just seemed to have more sparkle (I don't know what other word to use). Also like the simple ergonomics and hole in the bottom so it mounts directly onto a PA speaker stand - gigged it, rehearsed with it and haven't sold it so clearly I must like it.
    Forgot to update this - I bought it :).
    That's good to know. :)
    Great stuff, I'm dead happy with mine :)
  • DominicDominic Frets: 16013
    they are superb
    Old thread, I know... but I gigged mine last night for the first time and it was great. I'm assuming that there's no phantom power on the mic inputs, is there? Anyone know? @ICBM?
    Yes, there is - 36V, if it matters.
    Thanks @ICBM. Did you measure it? I only realised it might be there when I plugged in a DI box and it seemed to be getting power from the ACUS. From what I could see, there isn't any indication on the amp or in the online manual. Could that that adversely affect non phantom power mics? Honestly, I really don't understand how that stuff works - phantom power is as mysterious to me as its name suggests. I could easily it's made from ghosts. Nevertheless, IMH(and now clearly stupid)O, these are really great amps.
    Yes, I just stuck my multimeter in it ten minutes ago :).
    Unlikely, since any decent mic or other gadget designed to be connected to an XLR cable must be assumed to see phantom power at some point - but it's not impossible.
    It's really very simple - electricity is fed back up the signal cable to drive the electronics of whatever is at the other end - typically a condenser mic, but many DI boxes are designed for it too.
    Got it! You're right, it really is very simple. (But serious point... is it actually made of ghosts?) ;)
    That depends on whether you think ghosts are made from electrons or not :).
    Ha! I knew I was right. I ****ing love science.
