I also don't know if you would consider £499 a reasonable price, but that will be down to the owner rather than the shop! Also worth asking if it's negotiable.
0141 552 4848
And welcome to theFretBoard!
Cheers chap. That’s a bit on the pricey side. I’ve seen some go for between £195 and £350. Thanks for the heads up though.
Mint with box and anniversary booklet
Worth asking in case you really wanted one at cost no object though .
Easily changed from 3w to 1w by swapping the output tube.
These are great little amps although owners/sellers get caught up in the whole limited edition/discontinued stuff a tad too much.
£250-300 is reasonable for a head/combo. Any more than that is wishful thinking
• Youtube - https://www.youtube.com/@Goldeneraguitars
People seem to forget that it took the main dealers up to two years to shift the last of the 'limited edition', some for less than that *new*.
I ask as I've had a dsl 1 and a dsl 40, both a lot of fun and I found the DSL 40 was equally good at home volume , especially if you use the tone shift button.
Got it a blackstar ID Core 10 at the moment which does a job but want a smal valve combo, I’ve tried the blackstar 1 watt and just don’t like the tone.
Plus the ability to crank when I don’t have to be quiet is a bonus.
I would consider something like a DSL 5C which has a 1 watt switch and even at new prices they are less than some of the 1 watt amps.
You sound like you're interested in the same sort of models as I am / was when I was looking. I got a DSL5C last summer and love it. I then saw the JMP-1 on YouTube and felt like I had to have one but they are crazy money and I just can't justify it. I don't get the chance to crank the amp up much but the DSL5 does everything I need at low volumes and when I do get the chance to turn it up, it sounds great. It's not very big at all to be honest, mine is tucked in the corner of a bedroom and you wouldn't really know it was there.
I agree on the Blackstars too, I went in to buy an HT5R and on first listen it seemed perfectly fine, then I tried the DSL and it was no comparison, the Blackstar sounded so bland. I'm not sure what else I saw when I was looking that would fit the brief you've described. A Bassbreaker 007? I tried one of them too when buying my DSL and was pretty underwhelmed.
