We're looking to trigger some samples during our live set. Don't have to be sync's time wise. Don't want them looping. Just some vocals, sound effects etc.
What is a relatively easy bit of kit to use for this? I looked into iPhone apps, but none I found would simply trigger mp3 files saved on the phone.
http://www.dv247.com/guitars/digitech-jamman-stereo--71254?gclid=Cj0KCQjwybvPBRDBARIsAA7T2khQZstIrbS8GRptNUeHsWtFnFI3xsULNCYglMdginKvgj-CG9v2lAoaAkepEALw_wcB
Also chips are "Plant-based" no matter how you cook them.
If it's to be triggered by hand then a cheap laptop running Reaper is fine ... with the samples loaded at the beginning on separate tracks and solo mode set to exclusive, hitting the solo button on the next sample will automatically mute the rest.
Space bar is the trigger but it's not hard to fit another mico switch running to a push to make floor switch trigger
Voice memo on a phone can be used at a push
Jamup on an iPhone \ Ipad is great for samples, it can load from saved samples on the phone, free version is fine
