Fender super champ Bargain?
  • mbembe Frets: 1840
    What about 'hot-rodded' amps? Can they ever comply with regulations?
  • ICBMICBM Frets: 72237
    Yes. Most will have had no modifications to the mains side, and those that do are usually only fitted with an approved aftermarket mains transformer. They should be tested and PAT labelled though.
  • 57Deluxe57Deluxe Frets: 7332
    edited November 2017
    TBH - -the SCXD is an excellent little amp with a big voice when output through larger speakers.
    You will find one at a good price and it will be a rewarding amp. Unless you know the full extent of the issue with this donor, then the chance to make any significant savings is slim.
    <Vintage BOSS Upgrades>
