I think you should buy one.
Probably tomorrow.
HTH.
Are there internal organs that you could sell to finance a Gibson EB-650?
Of the few hollow body basses I've tried, I've always found them to be too wooly, this might be a good compromise.
http://thebassgallery.com/index.php/asat-semi-hollow-4447.html
No internal organs - apparently I need them..
Not as much, but still nice tho!
I can not believe that nobody has made the obvious gag about those organs for which you might have little or no use.
The controls are volume, tone and blend - I don't know about the P-Bass but on the Tele, the blend control works backwards - 'forwards' gives the piezo pickup - but is easily rewired. The one in the OP has had the Lace magnetic pickup and knobs replaced. The fretless one has also had the knobs replaced - they came with 'F top' knobs originally, but they very often get changed because the F tops fall off...
I've got a Duesenberg which is 30" scale but whilst it has a shorter decay than my Fender Jazz for example, being a semi with a central sustain block it has a much smoother sound than a fully-hollow one (just like the difference between a Casino and 335-type guitar).
- That acoustic p bass is lovely. Ibanez have got a couple of semi hollow basses out at the moment. Saw one in GAK a couple of weeks ago. Didn't try it but it looked quite nice. Will have a slinky neck profile unfortunately .
https://www.gak.co.uk/en/ibanez-srh500-def-semi-hollow-electric-bass-dragon-eye-burst-flat-/904880?gclid=CjwKCAiA9MTQBRAREiwAzmytw0PghcLV32Q3OflJVGaFl2eYVg01RzJA8guCVMT0V5iZ3_O_pIbsgBoCWqIQAvD_BwEI've got a semi-hollow 51Precision style body being made, along with a full scale wide nut vintage style Precision neck.
I am going to go for no pickguard, ultralight tuners and a fairly meaty bridge to try to keep the weight down but the balance spot on.
Build thread will start in a bit.
https://www.gear4music.com/Guitar-and-Bass/Schecter-dUg-Pinnick-Baron-H-Bass-Guitar-Black/1M16
