Micing your amp - what microphone?
1235»
  • CirrusCirrus Frets: 8491
    viz said:
    It's ok-ish. It doesn't sound as good as my amp, but that's just because it's going through the PA amp and speakers, instead of to my V30s cab.
    If only there was some device that could send the sounds coming out your speaker cab to the FOH...
  • vizviz Frets: 10691
  • ICBMICBM Frets: 72307
    Cirrus said:
    If only there was some device that could send the sounds coming out your speaker cab to the FOH…
    lol
    But more seriously, the real problem is to find a device that will send the sound *you hear on stage from several feet away from your cab* to the PA, so that it sounds the same out front as it does to you.
    Unfortunately the answer is not 'a microphone pressed up against the grille cloth'. One of the better DI/emulator boxes is probably no further away.
    ICBM said:
    lol
    Yes, I think if the PA's good enough then it'll be fine.
