DSL40C
Danny1969Danny1969 Frets: 10357
Just had a DSL40C come in which was making a terrible noise with nothing plugged in. New valves and a bias have sorted it out and it sounds nice ... it's just there's a bit of mains hum which doesn't get any louder when you turn up the amp and onstage you probably would't notice it but on a quiet front room it's annoying
Any words of wisdom of what I should be looking for on this amp or is this normal for this model ?
  • DJH83004DJH83004 Frets: 196
    Does changing over the triode / pentode switch make any appreciable difference?
  • Danny1969Danny1969 Frets: 10357
    Yes quieter in full power mode
  • I tried a brand new one in a shop and it hummed like a shop door tramp at any volume. I did not buy it.
    Checking back on my notes, on the last one I serviced, yours sounds typical, it is a very high gain amp, and not the best layout, I did think it would also benefit from from valve shields on the preamp valves, but alas not fitted.
    Thanks for that, one more thing a quick google suggested about 38mv for bias would you agree with that ?
    edited November 2017
    Again according to my notes I set it at 37.6mA @ 400Va which equates to around 60% max dissipation, which is what the customer had asked for.
    Edit: which across the 1 ohm cathode resistor, is about where you are.
  • ICBMICBM Frets: 71960
    Hum in triode mode is normal.
    I don't understand the logic of using it to be honest - it always hums at least a bit, it sounds shit and it doesn't give a useful volume reduction. The valves are pentodes and don't truly operate as triodes with the screen connected to the plate anyway, it's basically a bodge.
    Apart from a couple of blown valves I've seen no faults with the new-model DSL40C (as opposed to DSL401) at all.
    I fairness IC, this one just came just came in for a service and an output valve swap, so no issues, just a bit on the noisy side (preamp / gain wise). I did note that they only fed the heater of V1 with DC, putting a lot less stress on the bridge rectifiers.
    That's sensible.
    What's so stupid about the fault on the old model is that they could have fixed it very simply by adding a cheap heatsink - but they never did despite the problem being well-known for years.
