Just because you're paranoid, don't mean they're not after youEdit: which across the 1 ohm cathode resistor, is about where you are.
I don't understand the logic of using it to be honest - it always hums at least a bit, it sounds shit and it doesn't give a useful volume reduction. The valves are pentodes and don't truly operate as triodes with the screen connected to the plate anyway, it's basically a bodge.
Apart from a couple of blown valves I've seen no faults with the new-model DSL40C (as opposed to DSL401) at all.
What's so stupid about the fault on the old model is that they could have fixed it very simply by adding a cheap heatsink - but they never did despite the problem being well-known for years.
