Intonation question
If I'm getting notes on one string going massively sharp at the low frets, 1-about 5 but ok at the 12th... My problem is a nut groove that's too high?
  • WezVWezV Frets: 16668
    edited November 2017
    A statement as a question?
    likely a high nut, unless the nut is not high.  Then it’s a check on nut position
  • ToneControlToneControl Frets: 11891
    put a capo on the first fret, and check the 13th. If all OK, your nut is dodgy
  • Almost certainly a high nut. With a capo at the third fret, it should be possible to very lightly tap each string on to the first fret - in other words - there should be hardly any clearance.
    The only other possibility is that the nut is in the wrong place - very unlikely on a reasonable quality, factory-made guitar.
    It's my 2017 Gibson Traditional. I had thought it was just the strings were too light, but to properly fret the g string at the 1st fret, you have to push it down to the point of bending
    That is def a high nut slot.
  • Ok...related question. On a brand new guitar bought from a proper shop...should I expect them to deal with it or should I be taking it somewhere else?
    Unless you want to learn yourself, get a pro to do it.
    Closest person I know to you who I would trust with any job is @SteveRobinson over Manchester way.
    Thanks. That's not far from me. I'll drop Steve a pm
    Well worth getting him to do a setup - you'll want him to do all your guitars ;)
  • Or learn how to do it yourself (especially if you have several guitars).
  • ICBMICBM Frets: 72311
    In theory the shop should do it, for free. But having seen the work done by several techs working for large retailers, I would say that if it's an expensive guitar you really care about being right, I would rather pay someone known to be an expert.
    I'm happy to try most things, because they can be undone by someone more qualified if I fuck it up. Hacking away at my not very cheap Les Paul without prior experience or the correct tools I draw the line at. If it was one of my cheaper guitars I'd buy some files and have a go...
    I'd ask steve to do a fret dress as well - you will be amazed at the difference....
    The frets are bound Mark, and seem spot on to me.
    Worth a check, just in case tho ;)
  • vizviz Frets: 10691
    What's so bad about that.
    Nothing really, it just messes with my brain.
  • Many thanks to @SteveRobinson who sorted me out tonight. Bit of a nut file and needed a saddle turned. Very nice sir!
    Steve is the best!
  • LegionreturnsLegionreturns Frets: 7965
    Steve is the best!
    Well I haven't tried everyone, but he's certainly a nice guy that really knows his onions! Very reasonable too
