Double cut junior build with dual foil
DanielsguitarsDanielsguitars Frets: 3290
edited December 2017 in Making & Modding tFB Trader
I don't know why I never made a double cut junior sooner because I bloody love the thing, this is all limba loosely vintage based like old fret scale, body and neck dimensions but I wanted something different
my plan was to do a Pelham blue finish with a mojo dual foil pickup that I can split coil, I've had to wait to see if the pickup will direct mount or if I have to route the pickup cavity
http://i.imgur.com/t9yQDAF.jpg
www.danielsguitars.co.uk
(formerly customkits)
  • DanielsguitarsDanielsguitars Frets: 3290
    edited December 2017 tFB Trader
    I made the neck with a vintage spec truss rod with maple filler strip, I used a pre radiused and slotted Indian rosewood board which was to cheat time but didn't work out any quicker because it was too thick, won't bother doing that again
    http://i.imgur.com/GlRyI7K.jpg
  • WezVWezV Frets: 16665
    I like the look of this, especially with the finish and pickup choice.
    Do you need some dimensions for the pickup?  it is very shallow and I would expect it to surface mount without issues assuming you are using a wraptail.
    I tapered the board to fit the neck and pin it in a couple of places through the dot markers then glue it on, I use hot hide glue because I like it but you've got to work very quick, I use a very thick rubber band instead of clamps and it works great, I also use it for bindings too
    Here it is bound up and I glued the neck in at the same time
    http://i.imgur.com/ymVqdat.jpg
    I cut some cellulose nitrate dots out, I just had the sheet handy so used it
    http://i.imgur.com/MvdvkLB.jpg
    WezV said: please
    Thanks wez, yes I looked at dimensions, pickup should be here friday
    I'm using a mojoaxe wraparound, this thing is bloody good plays straight out the box with no fret dress yet, I'll be making more of these dc styles with different specs, very light and comfortable too
  • SeshSesh Frets: 1841
    Watching with interest...
    Can't sing, can't dance, can handle a guitar a little.
  • Love the Limba - that is one very attractive guitar :)
  • Looking great
    I got a basic set up done with a temporary nut and action about where I want it, I used a trapeze to set the mojoaxe wraparound up, I also clamp down the trapeze to get a bigger break angle over the adaptation then I set intonation mark it drill for bushings and hope it's right
    I only use the bloody long vintage bushings, they're 30mm long, especially in limba as it's quite soft,  don't want any leaning posts ever thanks
    http://i.imgur.com/Af4k4ku.jpg
    Here it is with a mojoaxe vintage pickguard which looks great to me
    http://i.imgur.com/xRfQ5tU.jpg
    That's all for now while I work on pickup wiring and get it ready for finishing
  • BigMonkaBigMonka Frets: 1770
    That's seriously cool! Are you still planning on Pelham blue, or are you going to show off that lovely limba?
    I'm just really gassing for a Pelham blue guitar then I thought a big gold foil would look great
    I've got more limba if i wanted to do another one, love the stuff
  • sawyersawyer Frets: 732
    Love these build threads! Lookin cool. Do you not fancy doin one with the full vintage correct thing? Be awesome! You'be obviously have the skill.:)
    This is funny.  @customkits  is normally the one saying I should be more vintage correct :)
    Your Gold Top build was fantastic btw!
    I do enough vintage correct stuff and I'm not doing juniors unless someone's paying
    I've also got an original 58 tv model basket case to restore, that's where the specs came from
    you're becoming a bad influence lol
    seriously though I'm interested in doing various things loosely vintage based, one example is I fancy a fender scale dc junior with tele bridge pickup etc plus loads more
  • DougDoug Frets: 172
    +1
