C18Q1 swampy strat... FINISHED with pics.
  • poopotpoopot Frets: 9099
    Well there’s good news and there’s bad news...
    the good news:
    fresh nitro (hour old) is really easy to strip from a guitar!....
    the bad news:
    ive used all of the missuses nail polish remover!!!!
    this clear white is a bugger to spray!
  • m_cm_c Frets: 1239
    Any light colour is usually tougher to spray due to the light pigment, and not being able to see just how thick the coat is.
    Rather than gauging how much you've put on by looking directly at the colour/shade, try and get enough light at a suitable angle so you can see in the reflection how the current coat is laying down. You're aiming for just enough so the coat goes smooth. Too little, and you'll see from what just looks like a layer of dust, to little pinholes holes in the surface (if they're big holes, then you've got contamination, which is repelling the paint). Off course too much, and the only thing you'll be seeing are runs!
    I had the damn thing finished... just got slightly too close with the spray at the last minute and got a run... it pulled the colour away as it ran...
    had to to strip it back and will start again!
    http://a63.tinypic.com/avn252.jpg
    Damn! That is so frustrating!
    edited January 2018
    Yip!....
    its had a final final coat of sealer now... so back to where I was two days ago... I have one more can of see thro white... if it works, great... I suspect I will be ordering a solid colour soon tho’
    One can of white blonde on...
    a bit bit uneven so will need to get another can I think!...
    http://a65.tinypic.com/ejymc2.jpg
  • WezVWezV Frets: 16668
    I would burst the edges slightly on the next go....  just leave the centre till last and stop right there if you like the Mary Kaye look
    Looks great!
    I’m going to go for a bit more coverage all over I think... just a hint of the grain showing through.
  • RockerRocker Frets: 4980
    What exactly is a 'Swampy Strat'?  Pardon my ignorance but I do have a Fender Strat and a Strat shaped Anderson but the term 'Swampy' has me baffled.  My Anderson is built from swamp ask IMMSMR, thanks.
    I am enjoying reading about your build.  Looking good...
    Nil Satis Nisi Optimum
    edited January 2018
    The body is swampash... just liked the title “swampy”   (also, and quite sadly, I do name my guitars... so swampy it’s is)
  • GoldenEraGuitarsGoldenEraGuitars Frets: 8823
    Swampy? Swamp ash?
    Looks good bud. Enjoying seeing you progress through this.
    The body is made of swamp ash, by the looks of it. That’s my guess.
    lonestar said:
    Swampy? Swamp ash?
    Thanks, if I balls this up again it’s coming to you for a sunburst!
    Right then... aesthetic settled on!...
    if if I can get the correct neck, I will be aiming somewhere close to the images for the final look!... Just need an all rosewood neck :/
    poopot said:
    lonestar said:
    Swampy? Swamp ash?
    Ha no worries but I think you’ll get a blonde out of this project no problem :)
  • TTonyTTony Frets: 27458
    poopot said:
    Are you practising acupuncture as well?
    :D
    TTony said:
    :D
    Had to teach it a lesson for the paint run first time round!!!! :)
    edited January 2018
    Liking the gold anodised scratchplate and Rosewood neck, suits it well.....
    Should look good... just have to get an anodised scratchplate and rosewood neck :)
    anyone have any ideas on the neck?
