C18Q1 Learn electronics and build a pedal
PhiltrePhiltre Frets: 4173
edited December 2017 in Making & Modding
So, my challenge is:
  • to have a deeper understanding of electronics (as I mentioned in my other thread)
  • get all the components together, breadboard, multimeter, etc
  • study the schematics and choose a pedal to prototype
  • build the pedal on a breadboard and understand what's going on
  • build the pedal on a PCB or vero board in an enclosure
So far, I've made quite a bit of progress as I've studied a few electronics books, got some components and tools from Bitsbox and put together some basic circuits on a breadboard. Heck, I even made a power capacitor discharge cable, some flashing traffic light LEDs, and I know what a 555 and decade counter chip does, and ohm's law! And now I'm learning about op amps.
«13456712
  • PhiltrePhiltre Frets: 4173
    Oh yeah, apparently, the theme of this challenge is "(Santa didn't bring it so) I had to make it myself". OK, so Santa didn't bring me a Timmy pedal so I will have to make it myself. :-)
    It's the first day of the C18Q1 challenge and I have the 'flu. Nevertheless, I will continue. Bleugh...
    So, I've decided to build a Timmy clone based on the schematic I found online. The initial aim is to put this together on a breadboard, with the simplest of offboard components - i.e no footswitch, no LED, in and out jacks wired loosely, and trim pots for the 4 pots because I can't be arsed to have dangling wires. Initially, that is. I want to be able to experiment with different value components and types of capacitor and understand what each thing does, rather than just blindly cobbling it together. Actually, it might be interesting to also try something else for the dual op-amp IC, the JRC4559. Any suggestions?
    Later today I'll order some components from Bitsbox. Still not sure what type of non-polarised caps to use - I understand the use of electrolytics, but for the decoupling caps there's polyester film, multilayer ceramic, polybox, polypropylene...not sure which to use.
  • Adam_MDAdam_MD Frets: 3420
    edited January 2018
    Try a lm1458 ic Paul C used to offer that as an option in the Timmy.  A good old jrc4558 will sound good too.
    As for the caps at pedal voltages if they’re good quality you’re unlikely to hear much difference between them if they’re the same value.  Some cheaper ceramics will just introduce noise so make sure you use NPO ceramics.  Most pedal builders tend to use poly box or NPO/COG MLCC caps because they sound good, are quiet and they’re the right size.
    When I was starting out and ordering caps based on the right value without paying attention to size or power rating I accidentally ordered some massive buggers which I wasn’t able to use.
    Now i order 5% poly box film caps with a 5mm pitch for all nf values, NPO/cog ceramics/mlcc with a 2.5mm pitch for pf and mini electrolytics for uf with a height of 5 or 7mm to give me as much room to fit everything in an enclosure as possible.  Electrolytics can get very tall if you’re not paying attention when ordering them and  fitting anything over 11mm in a 1590b enclosure is a real challenge.
    Good luck with your exploration it’s a very addictive but fun hobby.
    Yep, I've put both of those on the components order.
    As for caps, I'm a bit confused why there's a mixture of different types used in a project. I'm ordering my components from Bitsbox and they have  a Timmy kit - https://www.bitsbox.co.uk/index.php?main_page=product_info&cPath=280_281&products_id=2046 but the caps they specify are mixed:
    • 1x 47nF Polyester Film
    • 1x 10nF Polyester Film
    • 1x 39nF Polyester Film
    • 2x 1uF Multilayer Ceramic
    Why not all Polyester Film? Or all Multilayer Ceramic?
    Cheers!
    edited January 2018
    The 1uf mlcc has been picked due to the size vs the 1uf film cap.  This one is 10mm tall and quite wide though I’d still rather use a film cap than the MLCC from bitsbox because I don’t know what the tolerance or dielectric is.  Stick some of these on your order too so you can experiment.
    https://www.bitsbox.co.uk/index.php?main_page=product_info&cPath=65_76_77&products_id=361
    I’d also use one of these instead of the 100pf ceramic disc in that kit.  It will have a tighter tolerance and less noise.
    https://www.bitsbox.co.uk/index.php?main_page=product_info&cPath=65_75_318&products_id=2218
    Bitsbox sell cap kits. Would it be worth getting one or both of these?:
    Multilayer Ceramic Kit https://www.bitsbox.co.uk/index.php?main_page=product_info&cPath=65_286&products_id=1992
    Polyester Polybox Kit https://www.bitsbox.co.uk/index.php?main_page=product_info&cPath=65_286&products_id=1994
    I bought both of those when I started and only used the poly boxes I still have the mlcc caps in a box somewhere.  Honestly if you’re buying ceramic for audio purposes you need to get some which are NPO or COG dielectric.
    I replaced the ceramics in my early bitsbox builds with NPO ceramic caps and the difference was huge they had a lot less noise and sounded much better definitely less harsh.
  • m_cm_c Frets: 1238
    Adam knows better about audio usage than me, but in general the type of cap depends on the application.
    Electrolytic are typically polarised (I.e. they have a + and -, get them wrong they'll most likely leak or go bang), but they get used because they give you the most capacitance per volume, however they're not the most efficient type capacitor. They're typically used where you need lots of capacitance, and if you need lots of smoothing, you'd pair them with a ceramic capacitor (Electrolytic will handle low frequency voltage ripple, whereas the ceramic will handle any higher frequency ripple).
    Polyester are probably the most bulky in terms of capacitance per volume, but they are non-polarised, and very good at handling varying frequencies.
    Ceramic again usually fall in between polyester and electrolytic, but there are different types.
    The only time I've used ceramic, is for filtering on SMD PCBs, as they're nice and durable for reflow soldering, compared with other types.
    It's probably worth having a read of this discussion - https://electronics.stackexchange.com/questions/69919/ceramic-vs-film-capacitor-which-one-is-preferred-in-audio-circuits
    OK, I'll pop a couple of NPO 100pf and the Polybox kit onto the order. Thanks for advice!
    For reference this is the Timmy schematic:
    timmyver3wj0
    If you want to see how different values can affect things, look into SPICE (Simulation Program with Integrated Circuit Emphasis - yes I just had to google for the correct name!).
    I've played with LTspice in the past - http://www.linear.com/designtools/software/ but a quick search has turned up an online simulator - http://www.partsim.com/simulator#
    What they let you do, is take the likes of that timmy circuit, create a model of it, and the see how it reacts to different signals. Although aimed at testing circuits before you make them, it is actually a very good learning tool, as it lets you see what's going on, and how changing components affects the output.
    edited January 2018
    timmyver3wj0
    Have a look at the amp 11 and jan Ray schematics as well they’re only a few components different from the Timmy you might as well breadboard those as well while working on the Timmy.
    http://tagboardeffects.blogspot.co.uk/2013/03/vemuram-jan-ray.html?m=1
    Thanks @m_c I’ve never seen that before thanks for sharing I’ll have a play with this later.
    I'm on it! Cheers.
  • Danny1969Danny1969 Frets: 10402
    The thing that irks me is the insistence of pedal guys drawing the bias circuit separately like it's a power supply ..... 2 resistors acting as a potential divider is just biasing the non inverting input at half the supply, just draw this bias in with the circuit ...
    Almost every overdrive I've ever seen is basically an opamp with clipping diodes in the negative feedback loop so if you build a basic non inverting config and run 2 wires from pin 7 and pin 2 (on dual opamp as used in most pedals) you can experiment with different diodes and the gain without having to solder things in and out of the circuit board just by connecting the diodes and gain pot \ fixed resistor between these 2 wires
    I'm no expert (yet!) but is this a thing that comes from the way valve amp schematics are drawn?
    It's just to do with neatness. If you look at the Timmy diagram, the Vref output from the bias circuit is used in 3 different places.
    If you didn't draw it separate, then you'd have a few extra wires linking things, which would make it look cluttered. Plus by keeping it separate, it clearly identifies where the Vref actually is, and where it is being used.
    What is a "Vref" and why is it needed? Is it a positive or negative supply? From my (limited) knowledge the two resistors act as a voltage divider to create a smaller voltage (5v I think in this case).
    Opamps are designed to run from a duel supply, like +15 - 0 and -15V  ... a pedal only has a single +9V to run from so  basically by biasing the non inverting input halfway of the 9V we can pretend +4.5 V is 0V and then block the DC on the output with a cap
    OK, but the opamp still needs a +9v supply to pin 8 and negative ground to pin 4, right?
