Decal Removal
So I bought a nice Allparts neck on here some time ago. It has a Fender decal it which I wish to remove.
The decal appears to sit on top of the clear finish so what's the best way to remove it without damaging the finish underneath?
  • thermionicthermionic Frets: 9575
    Water?
  • JalapenoJalapeno Frets: 6385
    Yep, water unless it's been lacquered on - then gentle sanding is your only option.
    Feedback
  • GagarynGagaryn Frets: 1553
    Water will do it. Or if it is anything like my JM, just leave it a while and it will fall off! :-p
  • JD50JD50 Frets: 658
    Thanks all. Will have a go at the weekend & report back.
  • RolandRoland Frets: 8679
    If it’s been thinly lacquered over then you might find that a cabinet scraper will crack off the top layer
  • prowlaprowla Frets: 4915
    You could try lightly scratching it with your fingernail to see if it comes off easily.
