Lazy J40 brand new but no sound
  • WazmeisterWazmeister Frets: 9445
    thebreeze said:
    I’ve just got the popcorn in.
    I'm staying in too...
  • PhiltrePhiltre Frets: 4164
    We gots to know...
  • koss59koss59 Frets: 845
    Is it just me or does there seem to be quite a lot of issues with these considering how few must be out there? On the Facebook group there’s always someone with problems. Not trying to stir up shit but genuinely interested in one for the future.
    Facebook.com/nashvillesounduk/
  • Now that is some support from an amp builder :)
  • DJH83004DJH83004 Frets: 196
    Definitely keep us posted, I have worked on J20s but not a J40, The main chassis layout is exactly as you would expect, but the reverb and vib/trem modules are pretty tightly packed, particularly the reverb which has the send / return valves and the reverb TX mounted on it.
    He’s a drummer so not amp minded.
    Tell him to plug a guitar into the amp B)
  • SunDevilSunDevil Frets: 511
    Sure he’s not got the speaker plugged into the extension jack? - that’d do it
    My best mate uses a J20 (which I bought on his behalf as he was out of the country at the time) - it has behaved perfectly and as other people have said Jesse is a top bloke who absolutely stands by his products. I am afraid that as time goes on it is more and more poor vacuum tubes which seem to cause the majority of problems in amps.
    HTH
    Dave
  • MajorscaleMajorscale Frets: 1553
    Had my J20 since 2012 and it’s performed flawlessly for a bit of balance...
    Given it has been shipped I would re-iterate check the speaker terminals if he hasn’t got round to it yet
  • crunchmancrunchman Frets: 11411
    I've got a really early J20 that I probably got sometime around 2007.  Only problem in all that time was the contacts on the input jack socket needed cleaning.
  • cbellangacbellanga Frets: 572
    exactly the same for me .. solved in a sec with WD40
  • GadgetGadget Frets: 895
    WD40? Is that good to use on jack sockets?
    I think, therefore.... I... ummmm........
    worked perfectly for me (cleaned the residue with a cloth after)
  • robinbowesrobinbowes Frets: 3021
    Not really, no. You're better using proper contact cleaner - WD40 leaves a bit of a sticky mess, which attracts more dirt, which means the problem comes back sooner.
    R.
  • lukedlblukedlb Frets: 488
    Part 2 postponed until Saturday.
  • ICBMICBM Frets: 71952
    I use WD-40 on pots, but only as a second attempt solution if proper contact cleaner has been tried at least twice and failed - because then it's a shot to nothing, since you'll have to change the pot anyway otherwise. It very often does work, and as far as I've seen it doesn't tend to leave enough of a residue to attract further dirt, as long as it's in a closed amp chassis.
    And *don't* ever use it on rotary encoders such as the ones Line 6 use on the Variax guitars - firstly it won't do anything useful, and secondly I have it on extremely good authority from @impmann that it will attack some of the plastic parts inside and wreck the component.
    I keep meaning to buy some Caig Deoxit, which I've been told is ideal for such things. Expensive though.
    edited January 2018
    But bloody magic stuff. I got a can earlier this year and it's fixed a dodgy power connection on a mixer, some switches and pots in a Chapman Stick, and pretty much paid for itself.
    Good to know. Thanks.
