@Alnico's Blacker than black 16 Tonne Telecaster
    Side dots are black so ghost dots too...
    Blue Luminlay, man - would look extremely cool!
    Might be beyond my technical abilities ;)
    Some thoughts.
    Ink is messy. Very very messy. However, on a nice bit of wood, a really high quality permanent archive grade ink (which is what I used) does stain very nicely - it gives a very even coverage - I applied using a sponge and then wiped and rubbed in using a different sponge after the ink had absorbed for a bit.
    The Tru Oil took to it very well and darkened the ink substantially - as it's dried it's held that darkening.
    Ink is of course a mix of different colours and isn't true black - when it dries it takes on a purple tinge.
    The ink takes ales an hour or so to dry and absorb properly - you can see it transition in drying to a purple.
    Open grained woods take about two coats for good coverage - closed grain like the neck were three or four coats.
    I had had a small bottle of ink which cost about a fiver, and I used half a bottle.
    Theoretically you could Tru Oil this to the hilt and go full on gloss - but we are going for coal Black effect so will keep it satin.
    I was a bit skeptical about ink working - but it did - and a lot easier than I thought it would.
    Oh, and on end grain it drinks the ink like a thirsty farmer glugging his first cider of the day ;)
    If anyone fancies trying it - my ink is from the Writing Desk - https://www.thewritingdesk.co.uk/showproduct.php?brand=The+Writing+Desk&range=bottled+ink+100ml&cat=ink
    Avoid the common stuff you find in Smiths etc.. and it's probably not worth getting the really expensive stuff (tho I have a bottle of blue in the cupboard.. hmmm...)
  • Flink_PoydFlink_Poyd Frets: 2490
    edited January 2018
    impmann said:
    Oh and I was so hoping you were going to fit some of those neon pink strings for full comedic effect.
    May I suggest a headstock logo
    ”Model T Blackencaster”
    then in a smaller font underneath...
    ”None more black”
    All writen in black, natch...
    If we're having a naming game I'm in
    Bridgehouse - Blackestcaster
    Cinder
    Cinderhella
    Coalcaster
    Blackcaster
    Sooty
    Nobody is guaranteed tomorrow.....
    Looking good from here :)
    I think the neck looks absolutely splendid!
  • FunkfingersFunkfingers Frets: 14412
    If we're having a naming game ...
    Papalazaroucaster.
  • fandangofandango Frets: 2204
    fandango said:
    The Hot Black Desiato version
    Can’t resist giving you more ideas:
    Midnight Blackie
    The Black Whole
    And from leftfield, The Squink
    but if its going to turn purple, then maybe its got to be The Purple Nasty?
  • WezVWezV Frets: 16656
    Displaceacomedybassocaster
  • mikem8634mikem8634 Frets: 382
    edited January 2018
  • Side dots are black so ghost dots too...
    It's a doddle, really! Took me about an hour and a half on my first try, installing it on one of my Jadens.
    Goes like this:
    1 - Make an indentation with a pin in the centre of the existing dot.
    2 - By hand, using a drill bit the exact width of the dots you're going to install with the pin indentation as a guide, carefully "drill" through the dot until no more plastic comes out.
    3 - Dip the rod of Luminlay in the tiniest bit of superglue, and push it into the hole. Leave to take hold for a minute or so.
    4 - Cut the Luminlay rod as close to the wood as possible.
    5 - Repeat for all the other dots.
    6 - File the Luminlay down everywhere, then sand with 320 grit -> 600 grit -> 1200 grit.
    7 - Have a nice cup of tea, you've earned it.
    <space for hire>
  • ennspekennspek Frets: 1626
    I couldn't believe how good, how quickly this looked. Keeps getting better as well.
  • RockerRocker Frets: 4978
    Is it black enough for @Alnico though?
    If there are two holes for the pickups, and one for the control panel, what's the angled one between the two pickups for?
    It is a Reverb Tank.
    Nil Satis Nisi Optimum
    Are you sure? I thought that's where the mojo goes in.
  • DiscoStuDiscoStu Frets: 5459
    Nah, it's for his guyliner pencil.
    Black, obvs.
    Surely on this it would be a black jack rather than a mojo?
  • paulnb57paulnb57 Frets: 3053
    Noircoal?
  • AlnicoAlnico Frets: 4616
    BLACKJACK  !!!
    Thank you, we have a name.
    Just happens to also be the name of one of my closest friend's Horses and her username here...
     @Blackjack ;
    Don't Schecter make a Blackjack?
    I thought it was rowntrees to be honest
  • At least I'm going to manage one useful thing this year  ;)
