@Alnico's Blacker than black 16 Tonne Telecaster
  • GassageGassage Frets: 30865
    #blacktelesmatter
  • AlnicoAlnico Frets: 4616
    edited January 2018
    Here's the thing though....
    It'll have SC Humbucker(s) but I still can't decide.
    Esquire or Telecaster?
  • WezVWezV Frets: 16639
    single pickup.
    if you are not allowing colour variation why should you get a tonal one ;)
    edited January 2018
    single pickup.
    VERY good.
    Thanks Wez.
    What about the Esquire tonal controls?
    3 way switch.....
    1 - Blower - straight to the jack
    2 - Through Volume and Tone controls
    3 - Onboard Fuzz?
    Alnico said
    3 - Onboard Fuzz?
    There's no way a boss pedal will fit in the cavity mate ;)
    I know.
    What to do with the 3rd position then?
    Killswitch !!!
    Alnico said:
    I know.
    Killswitch !!!
    If it's a HB then coil split with tone/vol?
    Alnico said:
    I know.
    Killswitch !!!
    I prefer Killswitch.
    Maybe modify it so the pos 3 is spring loaded or try to find one that's like that?
    A split HB in the bridge won't have the sound I want.
    Alnico said:
    Alnico said:
    I know.
    Killswitch !!!
    You need to have a word with your fave pickup winder and see what might work ;)
  • I don't know if you could wire it with a three-way switch but a parallel mode on a mid-focused hot humbucker is a useful addition - can give something a bit more open and 'vintage-y'.
    I have a half-sized 'mini guitar' with a single SD HotRails wired with a series/split/parallel switch and the parallel mode comes in very useful.
    Nice.
    That sounds really cool.
    Alnico said:
    Alnico said:
    I know.
    Killswitch !!!
    I'm going to be speaking to the oily weasel very soon.
  • poopotpoopot Frets: 9099
    Alnico said
    3 - Onboard Fuzz?
    No... but a “bazz fuss” circuit would!!!!
    poopot said:
    Alnico said
    3 - Onboard Fuzz?
    Is it active?
    edited January 2018
    poopot said:
    Alnico said
    3 - Onboard Fuzz?
    Is it active?
    It’s a fuzz pedal that uses a ridiculously small number of parts for the circuit..
    http://a63.tinypic.com/2e6hvtz.jpg
    to give you an idea how small the circuit is the next pic is a 6x7 piece of vero
    http://a67.tinypic.com/e8wobq.jpg
    You could put the battery in the neck pup cavity and the fuzz circuit in the wiring channel.
    you would need a dpdt mini toggle to turn the effect on and a small pot for the amount of fuzz... load of room for that in the main wiring cavity if you use mini pots throughout I reckon...
    YouTube “bazz fuss”... its a nasty sounding circuit (in a good way)
    This’ll give you an idea:
    https://youtu.be/7_shXac8Vm0
    Ok then, maybe not fuzz.
    Thanks for posting it though.
    Or an “em drive”? If you go for the non mojo version it’ll fit! You’d still need a mini toggle, pot and battery tho’
    http://tagboardeffects.blogspot.co.uk/2013/01/emerson-custom-guitars-em-drive.html?m=1
  • BlackjackBlackjack Frets: 227
    That is going to be one awesome guitar!
    Cant wait to see it, especially if it does end up as Blackjack!  That would be a huge honour!!
    It's called 'Blackjack'
    I'm on ebay right now trying to find a decent badge for the headstock.
    Wow!!
    I am really honoured!!!
    A guitar with my name on is quite a big thing!
