£350 or trade: Rare OVERWATER custom built Strat - made in Cumbria by Chris May
RevMattRevMatt Frets: 829
edited January 2018 in Guitars £
This is an extremely rare guitar, made around 1980 by Chris May of Overwater Guitars. If you search Overwater now, you'll see that they specialise in basses costing £3000 upwards and they are a very highly regarded British firm. However their 6 string guitars are few and far between.
I bought this one when I was looking for a Strat and at the time it was in a very sorry state with a horrendous set up, the pickups didn't work correctly and it was unplayable. Since then I've re-wired the pickups, replacing the 5 way switch, I've replaced the vintage style tuners with a set of locking Sperzels, and I've thoroughly cleaned the guitar, polished the frets, oiled the fretboard and set it up with Rotosound 10 gauge strings.
There is a but... in doing all of the above, I discovered that the truss rod doesn't seem to work correctly - it just rotates. With the current set up the guitar plays well with a nice low action, but it is something you need to be aware of. In addition, the guitar has lots of scratches and marks that hints at its 38 year old vintage!
So, onto the spec - as you'll see from the pictures, this guitar is no typical Strat. It features a maple through neck, each side of the through neck is a nice birds eye maple top. I'm not sure what the body wings are made of on the back (they may also be maple), but it's a good chunk of something fairly heavy. The fingerboard is rosewood and features 24 wide low frets.Tuners are locking Sperzal and the bridge is a standard good quality item. I can't confirm what the pickups are, but they're configured as a pair of twin rail (single coil size) pickups, and a humbucker in the bridge. The humbucker states 'made in Japan' on the back and the rail pickups are marked with an 'R' - it's been suggested to me that they may be Bill Lawrence as this is consistent with what Overwater were using.
On the rare occasions that Overwater guitars come up for sale, you'll see them offered at over £1000. I'm asking a lot less (and less than it has cost me) to take into account the anomalies of this example, but don't be put off - it's a superb guitar that plays really well and sounds huge!
I've communicated with Chris May about this guitar and he replied, 'I can confirm we (I) built this guitar in the very early days of Overwater - from the serial number I would say in early 1980 and will have been made in our first little Overwater workshop unit in the village in Cumbria, from which we took the name… This will have been almost certainly been custom order through one of the shops and built to a customers specific specifications.'
If you like your custom built rarities, then this is a great one to add to the collection.
Price: £500 reduced to £425 and now £400 £350 collected from Nottingham or posted at cost
Trades: I have a number of trade ideas and am open to suggestions,  I may also include some cash either way depending on what you have:
Strats?
- USA or MIJ Fenders
- Levinson / Blade
- Carvin
- Warmoth
- Fernandes / Tokai
- ESP / Schecters
- possibly something more superstratty from Hamer,  Jackson, Charvel
Singlecuts?
PRS Tremonti or SC SE models
Gordon Smith
Eggles?
Always interested in any Eggles that are kicking around,  especially LA Pro II
  • FunkfingersFunkfingers Frets: 14323
    Going by looks alone, the rail pickups are Kent Armstrong/SKY. Bill Lawrence L45 pickups have shiny blade polepieces and no divide in the top of the bobbin.
    Be seeing you.
  • RevMattRevMatt Frets: 829
    I really can't say one way or the other. My Overwater guru suggested that the R on the bottom of the rails might refer to the Bill Lawrence 'Regular' pickups but maybe not. I'm fairly sure they're not KA Sky pickups and they don't have the usual label that Kent Armstrong use. But, then again, maybe they are...
  • BarneyBarney Frets: 614
    I would have been tempted by this off it wasn't for the truss rod issue  ...I have 2 overwater ...Great guitars
  • HarrySevenHarrySeven Frets: 8017
    Tempted too, but...indeed, the truss rod issue is a wee bit of a stumbling block. :(
    Forum feedback thread.    |     G&B interview #1 & #2   |  https://www.instagram.com/_harry_seven_/
    edited January 2018
    Thanks @Barney ; and @HarrySeven
    It's difficult to put a price on this given what could be worth and given the potential cost of getting it sorted, but I will consider offers so feel free to get in touch.
     It owes me more than I'm asking and the seller I bought it from was misleading in his description. It is a much better guitar now than it was then so hopefully someone will see the potential...
    I certainly do - and I’m interested - but the last fretboard-off trussrod repair/refinish, etc I had done cost me almost £300... :(
  • DodgeDodge Frets: 1430
    I had to have a fretboard-off truss rod replacement (albeit on a through neck bass) and my bill was similar.
    Worth the investment on an Overwater though - fine guitars indeed.
  • StrangefanStrangefan Frets: 5845
    What's the action like at the mo?
    Yeah ...it's a shame cos it could be a easy fix or maybe not ...no doubt it will be a great guitar when done ...
    Thanks @Dodge  - hopefully I've priced it in a way that makes it a good buy even after the worse case scenario, but as said,  open to discussion.
    @Strangefan ;
    Tuned to pitch with 10s the neck is straight with a low action and a few light buzzes depends on your playing style. There is scope to raise the action a bit.
    The way I've set it up,  and using the bottom E string, the top of the fret to the bottom of the string roughly measures:
    12th fret = 1.3mm
    7th fret = 1mm
    I've had a fair bit of interest in this but understand people's hesitation so (and I may regret this) I'll drop the price to £425!
    I'm making a big loss at that price and that stings a bit but it's got to be a good deal for someone,  even with the potential cost...
  • Musicman20Musicman20 Frets: 2296
    Good price and I bet Overwater would be willing to deal with any issues at a good price.
  • Have you contacted overwater? They might give some indication of a repair cost
  • I would have had it if it didn't have the neck issue. Such a shame
    Indeed,  although the price wouldn't be £425 if that was the case.
    Thanks.
    I don't really have the budget to undertake the work myself at the moment, but certainly worth considering - I'll ping them an email.
  • DeijavooDeijavoo Frets: 3298
    Would be well worth speaking to Haydn Williams too (he used to work there a long time ago) if Overwater don't take the job on.
    I've known the guys there for 20 years, Haydn longer in fact and their work is stunning.
    This guitar even with the repair work needed is a total bargain. If I ever played guitar these days I would snap this up.
    Thanks for the affirmation...
    Oh,  what the heck...  £400 but don't ask for free postage,  this is a cracking deal and leaves me with a big hole in my pocket.
  • beed84beed84 Frets: 2403
    At that price, I’d be inclined to get it fixed and sell it for more.
