I could just about get a tolerable sound on the Bluguitar (I think on all the channels in isolation, but I can't remember for sure), provided I didn't try radical changes of dynamics. It certainly didn't have that hideous overpowering, grating, fatiguing tone of the Micro Terror, and there was no 'after buzz' in my ears when I stopped playing.
So the Micro Terror's position as the Worst Amp Ever remains unchallenged for now...
Thank you very much for sharing information about Amp1 it really helps me to sorting out. I have a question about MIDI1 cable which is a mono jack not stereo. Could someone who has MIDI1 cable, check with multi-meter and share which midi pin connects which part of mono jack please? I am trying to solder my midi cable.
Thanks in advance!
I bought an Amp1 a couple of weeks ago having done some online 'research'... I've had back pain and been diagnosed with a couple of bulging lumbar disks, nothing serious but enough for my GP to tell me to stop lugging a Marshall combo around (a Haze 40, very nice despite some users hating it).
So anyway - I got the Amp1 and the pedal unit. No midi for me!
I have a couple of Celestion 10" 80W speakers in a homemade cabinet that I've been running a Fender 5E3 (Neil Young's amp) clone into quite successfully so I've been plugging the Blug into that. There's no way I can justify spending another £450 or so on the Nano or Fat Cab.
I play an SG with Burstbuckers, a Strat with Bareknuckle Rory Gallaghers and a Tele in open 'E' for slide so a VERY wide range of pickups and outputs.
I'm having second thoughts about the thing now, but will persevere a bit longer. I have found it's a devil of a thing to set up to get a really nice tone from, and it's so easy to get a nasty harsh vile-sounding fizzy distortion, takes some real dialling-in, just a half a step out on any of the tone controls and it's horrible.
What I HAVE found works is to have the master volume set to at least 8 in order to keep the nanotube driven hard; then set the Classic channel (which doesn't have side-panel trimmers) up with Bass/Middle/Treble controls set to 7, 4.5, 4.5; gain set to 3 and input master volume to control overall volume (i.e. NOT the 'main' master volume). Then set up the Vintage channel using the side-panel trimmers, and the Modern channel similarly (although I rarely use that channel for the stuff I play). I have the side-panel 'boost' control set to about 75%, which I find works best.
With this setup though, it's still difficult to get a 'crunch' out of the clean channel (even with 'boost' on) unless it's at ear-splitting volume so I have to use the power-brake facility on the pedal unit to tame it.
I'll give the thing another couple of weeks (and a gig next weekend) before deciding if I'm going to can it. I REALLY want it to work but I think it's going to be a hard slog to get there. In the back of my mind is a voice saying "No amp should be this finicky to make usable!"
Just ditch it before it's out of returns.
There are so many better options.
