however this comparison boss sounds better? But the 35ft cable is going to the pedals then a patch cable into the amp. Isn’t the buffer meant before a long length if cable? Ie the start of the chain or the end before a long length going back
https://youtu.be/d5W4-17q0V0
After experimenting today I actually prefer the buffer to be placed after overdrives before modulation.
http://www.thefretboard.co.uk/discussion/99893/gigrig-g2-vs-midi8-which-switch-unit-for-you#latest
Can't wait to get the board built.
Exciting!
Thanks for all your help
