Re-bevel a Pickguard - Jazzmaster tort content
GagarynGagaryn Frets: 1553
edited February 2018 in Making & Modding
I've been looking for a decent reasonably priced tort guard for a while. One of the things that makes modern pick guards look worse than older ones is that Old ones had a shallower bevel than modern ones - plus older ones are generally nicer tort. Anyway - pick up this one on eBay, it's WD Music (and came loaded with pots, jack and switches currently surplus to requirements in parts box) and looked nice enough but could be better, I thought. So I mounted a stanley blade at 30 degrees to a bit of wood and done some scraping. Went from this (eBay listing pics) -
  • GagarynGagaryn Frets: 1553
    And after some light ageing and scraping looked this -
  • Nice job, have you done something to the tort as well? It looks nicer in the after pics!
    Different lighting probably, and I re-polished it, and I think having the softer transition from top to edge just makes it look better!
  • FunkfingersFunkfingers Frets: 14323
    The change of background colour influences how we perceive the hue. More intense lighting (or flash) would explain the change in colour saturation.
    @HarrySeven could probably give a whole lecture on this topic.
    Be seeing you.
  • The change of background colour influences how we perceive the hue. More intense lighting (or flash) would explain the change in colour saturation.
    True.
    Forum feedback thread.    |     G&B interview #1 & #2   |  https://www.instagram.com/_harry_seven_/
  • Nice job.
    I have a vintage bevel cutter for my fixed router but it just loves to take a chunk out of pickguards.
    Found a picture of the original tort guard (it's had an aluminium guard for a while). The original was particularly poor -
  • That looks really great. What’s the JM? MIM Lacuqer series?
    Pretty certain it’s custom shop
  • rexterrexter Frets: 369
    Looks great man. The tiny bevel on those WD ones does really bug me too. Think there are a couple of US sellers on ebay who basically do this and charge double the price for them!
    Custom colours, vintage restorations, high end guitar finishing
    www.rexterguitars.co.uk
    Yes, it’s CS. The eagle eyed amongst you might have noticed the fret markers have changed colour too, I love the look of old clay dots so I’ve helped these get the look using these - https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F361337726932
    They’ve worked a treat
    They are useful things. I used them to take the freshness off the new bevel too - drew around the age then polished off, the colour gets left in the tool marks. For a man who is anti-relic I seem to spend far too much time doing stuff like this!
  • How long have you had your CS jazzmaster fella?
    It's a 2009, my mate bought it new in 2010, I've had it on loan about a dozen times and finally bought it from him about 6 months ago. It's a good one!
    Spec sheet -
  • WezVWezV Frets: 16547
    You ever notice that darker fretboards tend to end up with darker dots?
    if you have the right material for your clay dots a rub of the board wig naphtha is enough to tint the dot.  Sadly it doesn’t work on most of the repros
    Yip, believe the original were vulcanised fibreboard - it wood pick up the oils from the wood. These are some sort of plastic but it takes a stain.
    I was trying to work out how old it was due to the aged finish.
    I don't usually like fiesta red but I do like it on your jazzmaster
    I use old poker chips as harvite is one of the materials reported to be used
