HELP. Recording, mixing, production-ing, etc.
TTonyTTony Frets: 27346
This is prompted by me comparing the expertise demonstrated by some of the riffs submitted to the various "of the month" challenges, and the ineptitude of my efforts.
There are clearly some people here (quite a few) who know how to get a good sound from their recording.  And there's me.
I'm guessing some of it will be down to kit used, but that probably more of it is down to knowing how to use whatever that kit is.
I've got a basic set-up.  Guitar into iPad, and then various iPad apps to record/mix/etc.
Any decent "how to" guides out there?  Books, YT channels, whatever ...
HELP!
  • spark240spark240 Frets: 2073
    Wow !...Thats a big question...I found the best way , other than keep doing it loads is to get feedback from others, try their ideas for production and mixing, send other people your tracks and let them remix, see what they do, some things you will like and want to understand how to do it.
    I would have to say that for me, being able to work to a click track and practice your takes lots before taking on a serious recording, too many people stick something down which is a bit rough but cant be arsed to do it again, I might do 10 or more attempts to get a guitar part right.
    Tale a look at Warren Huarts Produce like a pro Youtube vids...or Johnny Geib...some stuff is pretty heavy but there are also loads of great ideas .
    Or....just take a trip up here and well have a day recording !...simples.
    Mac Mini M1
    Presonus Studio One V5
     https://twitter.com/spark240
    Reddit r/newmusicreview
  • Modulus_AmpsModulus_Amps Frets: 2570
    I am on the same boat Tony, I don't have proper studio monitors and assume that is part of my problem.... so it just fuels the GAS
  • octatonicoctatonic Frets: 33725
    edited February 2018
    It is a deep topic.
    In broad strokes recording a guitar signal is all about balance.
    Take a Fender/Fender or Gibson/Marshall combination and stick an SM57 in front of an amp.
    Turn the gain down and the power amp up.
    Keep the bass down too- you don't want to get in the way of the bassist.
    Guitar modelling essentially tries to do away with the speaker and microphone element.
    Results can be mixed and the more money you spend usually equals a better approximation that can be done cheaper using a real amp and a £100 microphone.
    That said, all of the guitars for the last albums have been 100% Axe FX and no one has known otherwise.
    If you are going to spend money somewhere then spend it on transducers- microphones and monitors.
    Most people don't- they sink loads of money into plugins and modelling amps.
    It is mostly a waste of time if the microphones and monitors are right.
    Acoustic treatment matters too- more than most people think or budget for.
    Mmm...Maybe, most of my stuff is done on cans TBH, then a few listens on the monitors to tweak, I can usually tell in the cans what needs to happen to make it ok on monitors.
    Mac Mini M1
    Maybe someone can offer recording day instead of Jam day?
    Mac Mini M1
  • Honestly, it depends what kind of quality you want to go for. If you just want basic drum and guitar tracks, the iPad approach is probably OK. If, however, you're thinking about layered guitar tracks, drums, bass etc then you might want to consider grabbing an audio interface, Reaper and a drum plugin (EZ Drummer's probably a good one).
    I happen to like Warren Huart's YouTube channel (Produce Like a Pro) for production tips. Glenn Fricker's videos are great too; they're metal-focused, sure, but most of the ideas on there are pretty good general advice.
    <space for hire>
  • TTonyTTony Frets: 27346
    Now, there's an offer - thanks!
    That's what I'd like to avoid.
    Not because I'm a tight b'stard (though I may be), but more because I think that my (lack of) knowledge and understanding is more what I need to overcome rather than an absence of kit.
    I have guitar interface - not the best, but adequate.  I have iPads and MacBooks, so I have a loads of apps and GarageBand.  Again, not the best, but should be adequate.  I'm not aiming for pro-standard recording/production, just something that doesn't sound totally crap!
    @TTony check this out....
    Mac Mini M1
  • markvmarkv Frets: 459
    Maybe not quite what you're looking for but I found Paul White's book "The Producer's Manual" to be a really interesting guide to the topic.
  • steamabacussteamabacus Frets: 1258
    I know nothing about iPads and such but I think the two most important bits (kit-wise) are where it goes in and where it comes out.
    Guitars like to see a nice high input impedance (which a proper guitar amp will have) so a decent audio interface (with a good 'high Z' input) between the guitar and iPad will probably help.
    Monitoring what comes out (so you know what whatever you're recording really sounds like) is crucial. Without going down the rabbit hole of monitors, room treatment, etc, I think the best 'bang-for-buck' for a beginner is to invest in a set of decent 'reference' headphones (open back are better for sound). You should get something pretty decent for a couple of hundred quid or so. A cheap set of closed-back cans for recording in front of a mic (so they don't bleed sound into the mic) in addition if you intend to record like that.
    In terms of knowledge and techniques - well, it's a HUGE subject with many contrasting opinions. Practice and experience is the only way really.
    Finally, I recommend doing some kind of ear training to learn how to listen (yes, seriously). This course from Belfast Queen's University is free and very good ..
    https://www.futurelearn.com/courses/critical-listening-for-studio-production
    It is run at regular intervals (sign up to be notified). To get the best out of it, get some decent headphones.
  • digitalscreamdigitalscream Frets: 26465
    The thing is, Garageband kind of isolates you from the knowledge you want.
    If I were in your position (and I was, a couple of years back), I'd spend something like this, second-hand:
    Audio interface: £100 (probably a Komplete Audio 6 or similar interface with a couple of preamps)
    Active studio monitors: £120 (you might get lucky and pick up a pair of KRKs, or perhaps some passive Tannoys and a 20W T-path amp)
    Dynamic mic: £30-ish (the Superlux PRA-628 from Thomann is great new)
    Condenser mic: £60-ish (SE Electronic SE2000 on eBay)
    Reaper: £35
    EZDrummer 2: £114
    The mics are optional, but I found that an understanding of the differences between dynamic and condenser mics is pretty critical to getting a good sound even with modelling. It really is worth sticking mics in front of cabs, even if you're not at massive volumes (the Superlux is great for that, because it's super-cardioid and has excellent background noise rejection).
    To begin with, you'll be making tracks that are measurably worse than anything you produced with Garageband. However, you'll be learning, and as long as you pay attention to what you're doing you'll start to realise where GB's limitations are and why this approach is better.
    <space for hire>
    I consider myself in the same boat.
    As a recording newbie with small children in the house I have to record silently and mix with headphones. I use my amp head into a Boss GT 100 into Reaper so I can use a real preamp then add cab IRs and EQ. I can also record a dry signal at the same time to experiment with virtual amps or even reamp with different amp settings at a later date. I think I'll experiment and try to get the best out of this approach for the time being. Micing up a cab is a no go for now.
    I do upload private files to soundcloud so I can listen on my car stereo and send to my bandmates to listen and give their feedback about balance.
    Bearing all that in mind, when listening to the "OTM" submissions I am drawn to the best riffs regardless of the technical limitations or proficiency.
    And I'll keep it quiet that I recorded vocals for the comp challenge using a SM58 into a Jazz Chorus emulator in my GT100...
  • Step 1 - ditch the ipad
    Step 2 define budget and what you want to record. Acoustic, electric, vocals? drums?
  • FunkfingersFunkfingers Frets: 14324
    Paul White and Hugh Robjohns of Sound On Sound magazine
    https://www.soundonsound.com/shop/books
    Be seeing you.
    I have virtually never mic,ed a cab for guitar, I use the Kemper for electrics and a mix of DI and a pair of Rodes for acoustic, as @flying_pie said,usually the quality of melody and arrangement will often override sound quality, I also use a Radial di for Bass.
    Mac Mini M1
    Nothing at all wrong with the iPad. In fact, it can be better than a computer, because you can easily bring all the iOS music apps into your recording app. Apps and plugins are a lot cheaper, too. GarageBand on the iPad is now very powerful indeed.
    I recorded, builds, and recorded all all of these songs using GarageBand on iPad. If you’re listening, One Pussy Chiller sounds best, in mixing terms, because I mixed it after I got a pair of monitors. The others are done on headphones.
    https://soundcloud.com/mistercharlie/sets/blunt-knife-manifesto-ep
    A couple of tips. 1. Don’t record the guitar too hot. If you’re using GarageBand’s amp sims, this is especially true. You’ll get a better sound if you don’t slam the levels,up as high as you can get them.
    2. EQ your tracks so each one only occupies its own frequency space. Cut out the lowest bass on the guitar, for instance. This alone will make the mix sound open and clean. I’m a recording noob too, and these two tips made a big difference for me.
    Also, in GarageBand, use the Drummer. It’s like having a real drummer, only better.
  • Also, this is a great thread on the philosophy of recording, and putting songs together:
    http://www.tdpri.com/threads/thinking-like-a-producer.807129/
    Gainstaging is important- it should neither be too loud that it clips (or gets close to it) but neither do you want it so quiet that it disappears into the noisefloor.
    I tend to record guitars around -14dB.
    For the uninitiiated digital metering works like this- usually a signal will clip at 0dBFS.
    Anything under that won't.
    A -14dB single will be 14dB quieter than 0dBFS.
    When a signal overloads digitally it will sound very unpleasant- it isn't like an analogue circuit at all in this regard.
    I've done a bit of iPad recording- my issue with it isn't sound quality, but rather the lack of advance editing features compared to a full fat DAW.
  • IMC1980IMC1980 Frets: 141
    Don't know if I am qualified to chip in; I still feel like a beginner myself after 3-4 years of trying to wrap my head around producing a track end to end.
    As others have said, practice is the best way, youtube is good; reference tracks are also helpful to have on hand for sanity checks and plenty of reference speakers/headphones to test your mix versions out on. I use cheap earbuds, Audio Techinca M50x's, car stereos and monitor speakers to test out mixes.
    I can't remember where I read it, but one thing that has stuck with me is to get it right at the source, so as I generally mic up a guitar amp/cab, I spend a bit of time getting the right sound for each guitar part from the mics before keeping a take. That way I only need to add a high pass on an EQ to guitar channels and maybe a bit of compression on the guitar bus to glue them all.
    @Winny_Pooh ;
    1.  Why ditch the iPad?
    2.  I want to record electric.  My budget is minimal, mainly because I don't want to go out and buy a load of stuff only to find that I don't have the fundamental knowledge or capability of using it.  Hence I'd like to start with what I've got, and get the most out of that I can, understand the limitations of the kit, and then prioritise spending on new kit based on the constraints of what I've got.
    Reaper: £35
    EZDrummer 2: £114
    To begin with, you'll be making tracks that are measurably worse than anything you produced with Garageband. However, you'll be learning, and as long as you pay attention to what you're doing you'll start to realise where GB's limitations are and why this approach is better.  @Digitalscream - all built around my old MacBook?  Doubt I'm going to be mic'ing cabs anytime soon though, else I'll need to get into room acoustics and sound insulation ...
    Thanks to all for the various links to resources too.  I can spend some time reading & listening.
