Just fit it with the outer nut close to the end of the thread and leave off the strap button part. Then you can make the internal strengthening patch up to about an inch thick if you want!
Forgot to say... this type, there's more than one.
https://www.allparts.uk.com/products/end-pin-jack-stereo-can-be-tightened-from-outside-the-guitar-switchcraft
The 1/2" diameter bit doesn't go all the way to the outer nut, that bit is the standard 3/8" diameter so it won't look odd on the outside - you just need to make the hole in your strengthening piece 1/2".
And connect the unused ring terminal to ground as well, it improves the reliability.
Thanks!
And after all that I still forgot to say that you can use the jack itself as the clamp to glue the patch on the inside! There's a lot of adjustment range of both the inner and outer nuts so it's not difficult to do.
It's also best to leave off the cover part of the jack - it usually works loose and rattles, and isn't necessary - and the plain washer on the inside, it's better to have the grip washer pressing into the wood.
