Motivating yourself when you feel negative about your skills
  • BarneyBarney Frets: 614
    I think it's a good idea to really break things down..for example ..take a pentatonic scale and use maybe the top 2 strings and get as much mileage as you can just out of them using phrasing different note combinations ECT...it's surprising how many ideas you can come up with ..after a while you start knowing what the notes are going to sound like before you play them ...this will give true improvisation and not just lick playing ..you will start playing what you feel ...then repeat with G and B string ECT. .then 3 strings at a time ...then 4 ECT ..
