I don’t tend to play it plugged in and more recently I found it wasn’t quite loud enough for my needs so tried a few other guitars - and when you start that game you realise the deficiencies of the APX500 in terms of sound.
I’ve now got a Taylor GS Mini (for the purpose I was using the APX). It sounds much bigger than it’s diminutive size would suggest.
I’m not sure what a setup would do in terms of improving the sound of your guitar, after all the construction and materials used that contribute a great deal to the sound - and no setup can change those - after all the 500 is really an ‘entry level’ guitar.
Upgrade would be my advice.
Some of the higher end APX Series guitars are very nice guitars, however acoustic guitars are a very subjective topic, and, as I was advised, the best thing to do is try as many different ones as you can before deciding on your next purchase.
Good luck.
Testing the pricier Yamaha guitars at TGS should have demonstrated the benefits of solid woods over the all-laminate body construction of the APX500ii. IMO, if you can hear any difference, the time has come to upgrade. All you need is cash.
Damn you The Guitar Show and your Yamaha stand
I was quite taken with the A3CR / A3CM
If you are in the market for a higher end acoustic it's worth trying a few others as well. Don't just restrict yourself to Yamaha. I think there are better acoustic guitars out there. Yamaha are competent, but I've never been blown away by how good they sound.
@timmyo i dint remember tbh. They were down stairs and about 800 quid lol
Looked at Yamaha long and hard because they're reliable and usually good value for money etc. and then after doing a lot of research (i.e. looking at guitar porn at every opportunity, pissing away hours on YouTube, and traipsing around a few shops) I suddenly realised that whilst they were always impressive bits of kit, Yamaha stuff just didn't connect with me emotionally. They were a sensible choice, but they didn't particularly excite me in any way.
All of which led to some dreadful mission creep and <cough>what budget?</cough> moments, and the arrival of a Furch+Fishman arrangement. Which has been a thoroughly happy conclusion. Although I still have the horn for a dreadnought (ended up with a G) which could cause some domestic friction in due course.
Er, in your opinion, is there anything retailing under £1K that falls into this category?
