A couple of months back I picked up a s/h tubescreamer mini. I've owned a number of TS style drives before such as the bad monkey but hankered after the real thing.
I was expecting the gain levels to be similar to the other pedals I've tried or indeed similar level of gain on tap as a Boss SD-1 - however this thing has much less gain on tap.
I've found I'm having to stack it with my soul food however I just really want the TS drive on it's own without having to use another pedal to add more gain. I've a boss blues driver for my heavier gain sounds and that has bags more gain on tap.
Is this normal for a tubescreamer? The easy answer to this is ditch the tubescreamer and put my SD-1 back on the board however space is now at a serious limitation.
Eqd Speaker Cranker clone
http://www.thefretboard.co.uk/discussion/126818/fs-ft-mi-audio-blues-pro
(or find a super blues pro for all the TS goodness you could ever need and more)
Depends on what your expectations are really. If you're using a strat or something wimpy it wont have as much gain as something with hot humbuckers.
At rehearsals we use the amps in the room, peavey bandits (great amp like it a lot) however at gigs I use my Fender HRD which the TS Mini works really well with, plenty of nice crunchy gain on tap and sounded great.
