The current 'best choice' passive pickup if you're not using some sort of outboard modelling system (eg Fishman Aura) is the K&K Pure Mini, which costs about £100 and should cost about £40-£50 to fit professionally. If you're using a modelling system then you want an undersaddle transducer, the basic Fishman AG094 is still as good as it gets. They don't sound as natural when amplified directly though.
http://www.jjb-electronics.com/
There are three basic types:
Undersaddle transducer (UST) - often called a 'piezo' pickup because the technology is piezo-electric, fits under the bridge saddle and will need the saddle reducing in height and a hole drilling through into the guitar. They give a defined but rather artificial sound and are quite resistant to feedback. (eg Fishman AG094)
Contact transducer - these also work on the piezo-electric principle but are glued (permanently) on the inside of the guitar on the soundboard or bridgeplate and pick up the vibration from the body. They're the least invasive to fit and the most natural-sounding but can be more prone to feedback. (eg K&K Pure Mini)
Magnetic soundhole pickup - basically an electric guitar pickup with a slightly tweaked frequency response to sound more 'acoustic'. These can be fitted and removed easily and are resistant to feedback but don't sound as 'acoustic' in some ways, although some people think they're less artificial than a UST. (eg LR Baggs M1)
These can all also be bought with preamps, inside the pickup itself for the magnetic or fitted inside the guitar (usually on the endpin jack for the other two, but still without a control box cut into the side of the guitar. Some people like this because it avoids the need to use an external preamp and keeps the whole thing self-contained, but they still rely on batteries inside the guitar (or in the pickup, for magnetics).
I don't play it outside my room I plug my Electric in however ..am I mad?
Almost any system that you can install internally will be considered by Martin to invalidate the warranty.
Although that plus an external Aura is still a very good option.
Personally I don't like the sound of them anyway. The K&K sounds better.
The easiest to fit is the internal bridgeplate type. I have fitted two of these - an LR Baggs Ibeam, and a KK Pure Mini.
I preferred the Ibeam. LR Baggs also do the Anthem, which is more expensive, but highly rated.
I don't like the idea of having a battery in a little bag inside the guitar body. You can't change it, or even test it test it, without removing the strings. I fancy chopping a hole in the guitar and fitting a pre-amp even less!
You are not supposed to have a very long lead with the passive Ibeam. I just have a 1.2 metre lead going to an external pre-amp, (LR Baggs Para Acoustic DI).
Fitting wasn't too bad, and with a bridgeplate pick-up you can't do very much damage to the guitar. However, if you're not very good practically, then get it fitted. Fitting an under-saddle type (eg Piezo) is a different ball-game, and requires craftsman skills.
Having said all that, I'm not wild about any pick-up, and for live performances I just have a mike in front of the guitar!
@ICBM, have you tried something like a TC Bodyrez? That helps quite a lot when I use the guitar that only has a UST without the blend mic. You can pick one up for around £50 second hand. I've had mine for a couple of years and it hasn't died yet, so seems to be quite reliable by TC standards.
I did briefly consider the Boss AD-2, but it seems a waste to use a pedal with so little functionality when you can do a lot more with something only a little bigger. I'm actually getting an AD-8 this week, which should hopefully be the solution, even if it is a bit on the large side!
I recently replaced the nut and saddle on my ageing Martin DM. The acoustic sound with no UST has reminded me why I bought the guitar in the first instance.
The L.R. Baggs Anthem SL is off the guitar. I am trying to decide what will replace it. I already have a Baggs Lyric on another guitar. I suppose that I could just modify the Anthem SL.
Please do not suggest the Fishman Rare Earth Blend. I tried that before and found it wanting in several respects.
Of the common ones I actually like the standard Rare Earth best, I think.
Although Doug Young wrote his soundhole magnetics blog a decade ago now, it's still worth a read. See http://www.fingerpick.com/pickups.htm.
