The likelihood that anybody mass-produces a pickguard with the pickup cut-out in those dimensions is small. Hence, your options are;
- to use the existing pickups then, purchase and modify a blank J pickguard
- to use the existing pickguard then, purchase conventionally-sized J pickups
In your position, I would try the existing pickups in the bass sans pickguard. If you like the sounds, stick with the pickups. If they disappoint in anyway, investigate replacement units.In your earlier thread about this instrument, there was some mention of having Ash at Oil City Pickups rescue your pickups by rewinding them. It ought to be possible to have the copper coil of your original neck position pickup rewound onto a short J pickup bobbin.
Neither of these suggestions will be cheap.
Also, in your earlier thread about this instrument, there was an offer of some *surplus* Japanese pickups. It might be worth reconsidering those.
Good idea to try without the pickguard in place. I've not really given the bass a good work out yet (I'm a guitarist and this is just a cheap instrument to have hanging around in case I want to track some bass) so it would be good to give the original pickups a play and see how I like them.
I fixed the broken pickup, so no need to involve Ash at this stage.
I received the surplus pickups kindly sent by @BigLicks67 - I will also give those a try and see how they differ from the originals. They measure higher than the originals (7.28k bridge / 7.06k neck vs. 4.9k bridge / 4.7k neck). Also, the bridge pickup is slightly longer than the neck (the originals are both the same size).
I suspect my best option would be to use this as a project to learn how to cleanly cut a pickguard - it's something I've always wanted to learn to do! Any tips?
Thanks.
R.
Eqd Speaker Cranker clone
R.
