https://youtu.be/RI5LRsMtyjA
I would avoid penny whistles as they aren't chromatic (so far as I know), you'd want a chromatic instrument.
EDIT scrub that, they are also called melodians.
Youtube also comes up with the Kalimba which has the advantage of a much less abrasive tone than the melodica but isn’t chromatic, unless going for a special chromatic version which has notes on both sides, a bit complicated.
This is because you'll be able to play and hear intervals and harmonies. For example, you want to be able to play a root and a 3rd interval, and hear the harmony that the two notes make together.
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
Ukulele suffers from being tuned differently from guitar so it has neither that nor piano layout. Tempting for size and ease of use though.
Simple and fun and surprisingly versatile
