ALL SOLD - Line6 M9 and M5, EHX RingThing, EHX Tall Font Big Muff
CasperCasterCasperCaster Frets: 760
edited June 2018 in FX £
ALL SOLD
All pedals are in excellent condition, and boxed. Sorry, no trades at the moment. Items include postage to your UK mainland home address. I will post upon receipt of full payment by bank transfer (PayPal Gift/ PayPal Friends & Family also accepted but only for established forumites with good trading history). Cash on collection is also welcome from Ramsbottom just outside Bury (North Manchester), and I will be happy to deduct postage costs if you collect and pay in cash.
Line 6 M9 Multi-effects £175  £150 (Sold)
Immaculate as new condition (home use). Works perfectly and is boxed with instructions and original dedicated UK power supply. A very versatile unit which works effectively on its own as a virtual pedal board, or when supplemented with other pedals. The software is Version 2.04 (most recent version for M9). 100+ effects models from 3 dedicated FX units. 2 effect models are available per FX unit (‘A’ lower switches/ ‘B’ upper switches) with 3 effects being available simultaneous (1 per FX unit). Effects combinations are saved in 24 scenes, each containing 6 effects of which 3 are available simultaneously. Each scene is effectively its own virtual pedalboard. The bright back lit display changes colour with each effect type. Built in tuner and universal tap tempo. A 28-second looper features; Play/Stop, Undo/Redo, Rec/Overdub, Half Speed, Reverse and Play Once. The looper can be placed Pre/Post effects (selected in setup menu). 2x expression pedal inputs for control of multiple effects parameters (expression pedals optional). Mono/stereo inputs and outputs, Midi in/out and selectable true analog bypass or DSP bypass.https://i.imgur.com/To3ecA7.jpg https://i.imgur.com/3RIbrRf.jpg https://i.imgur.com/ojwU2RU.jpg https://i.imgur.com/koGsXFD.jpg
   Line 6 M5 Multi-effects £65  £60 (Sold)
Immaculate as new condition (home use). Works perfectly and is boxed with instructions and original dedicated UK power supply. A very useful pedal, it worked great as a ‘utility’ pedal in the middle of my effects chain e.g. if you don’t want a chorus pedal and a phaser pedal and a flanger pedal – just put this pedal in the middle of your board and it can be any of them (or anyone of the other 100+ effects - eq’s, compressors, drives, distortions, fuzzes, modulations, delays, reverbs, filters…) The software is Version 1.0 (only version M5). 100+ effects models are available. The single FX unit allows 1 effect to be used at once, but 24 preset memories mean that any 24 of the 100+ effects can be customised and available via the footswitches. The bright back lit display changes colour with different effect type. Built in tuner and universal tap tempo, plus a single expression pedal input for control of multiple effects parameters (expression pedal optional). Mono/stereo inputs and outputs, Midi in/out and selectable true analog bypass or DSP bypass.  https://i.imgur.com/Q2cXYrW.jpg https://i.imgur.com/PhRrDdS.jpg https://i.imgur.com/pkFW07o.jpg https://i.imgur.com/yZdUny9.jpg https://i.imgur.com/FngX1HB.jpg
Electro-Harmonix RingThing (ring modulator/ pitch/ modulation) £80 (Sold)
 An excellent pedal which will do pitch shifting, modulation and ring-mod effects. Nine memories. Various parameters can be controlled via an expression pedal (not included). Immaculate as new condition (home use only). Everything works perfectly and it is boxed with the instructions and original dedicated UK power supply.https://i.imgur.com/DmQS6Fi.jpg https://i.imgur.com/WvFaiWW.jpg https://i.imgur.com/g0TgMxI.jpg
Electro-Harmonix Original Green Russian Big Muff, Tall Font/V7 £185 (Sold)
Excellent condition, I doubt there is another one currently for sale in this condition. It has only been out of its box a few times since I bought it new, I think in late 1994. It sounds exactly as you would expect, but I guess I’m just not a Big Muff person! Anyway, everything is there – the original wooden box and strange rubbery pad that sits inside it, all the knobs, the battery door, and the feet. And of course everything works as it should. If you have to have an original Green Russian then this is an excellent all original example.
https://i.imgur.com/9VjJJOj.jpg
https://i.imgur.com/BksrTlL.jpg
https://i.imgur.com/84cGkfJ.jpg
https://i.imgur.com/fJWnGls.jpg
https://i.imgur.com/Dj6WgFa.jpg
https://i.imgur.com/vT9FKGx.jpg
https://i.imgur.com/N0TfNOj.jpg
https://i.imgur.com/Q0nz3fs.jpg
https://i.imgur.com/WbvO9hs.jpg
