Still learning...
I have a super cheap Chinese archtop with an action that's about the same as an average electric, but I hit it a lot harder, so I can make it buzz out slightly if I'm aggressive enough.
For classical, I'd definitely want the action somewhat higher than the average electric, because some of the right hand techniques displace the strings more vertically.
Only one way to find out I guess… just wanted to check I wasn’t making a fundamental error before I break out the files.
I always get the neck straight and sort the nut out and that normally gives me an action that doesn't rattle.
My electrics generally measure around 1.5mm at the octave on the low E - my acoustic is 2.5mm - but looks at least twice as high as the electrics.
Its certainly the case that volume is usually significantly compromised when the action is set too low on an acoustic.
