Using primer as a finish?
  • GoldenEraGuitarsGoldenEraGuitars Frets: 8823
    paulnb57 said:
    lonestar said:
    paulnb57 said:
    lonestar said:
    Okay I’ll chime in again. This is do able in nitro but not with aerosols.
    Out of interest oh paint guru, why is it not achievable with aerosols?
    If I was to get that colour I’d do a custom grey mix and test it first. Then I’d apply on white primer. Finish off with matte clear coat.
    The reason i said that it’s not achievable with cans is because of how I’d do it. But I have to mix my colours anyway for spraying, I don’t use aerosols.
    I thought you meant it wasn't achievable with aerosols period........I like the look though, so might give it a go with rattle cans...
    You can do it if you can find the grey in an aerosol and clear over it but of course I’m going to say that using the right equipment helps. Obviously I concede that not everyone has access to such equipment, however.
    edited May 2018
    If I can get Satin Celly, then I wont use clear coat, the colour shouldn't be a problem as they have huge swatches, just never asked for Satin before...
